> I'm not really sure that using object names would be sort of the best fit for that though,
> it seems like a kind of "variable manager" type UI would be the thing -
> like you would go somewhere and push a button for "define variable",
> and you could pick from different functions like get the distance between 2 picked points,
> take the length of a selected edge, radius value, etc... and then you enter a name and
> then that variable would be defined for use in expressions.
Yeah that would work, but I was thinking even with the idea I gave there are too many steps and typing involved, something with less steps, like if you had that 'define variable' or 'reference' button beside each input box (x, y, z) as a small button and once pressed you can pick that edge mentioned previously and the length value would be placed in the input box.
But then as you implied, how many times would we use it, just thinking out loud.
Keep up the good work
~Danny~ |
