Scene managment....?...
 1-5  6-25  26-45  46-65  66-85  …  126-135
2150.26
Looking good so far....
1) Will object browser / scene tree be within the same panel / area ?
2) I think units labels makes seance if they where somewhere close as PaQ mentioned.
Thought will it be more comfortable to the eye, intuitive if they on the top right corner ?...
2150.27 In reply to 2150.26
Hi yannada,
I think that is going to be an additional full size docked panel to the left of the current side pane, something like what was discussed here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1944.1
2150.28
Okay Michael, I'm gonna jump out on a limb here...
Constraints. We already have them to a certain extent. I can limit tools to certain distances/angles already. But, what about preserving those distances/angles?
I have no idea how the GUI would represent a constraint, but, seems like the toolset is there already, just need a way to preserve the constraints as we continue working.
2150.29 In reply to 2150.28
Hi TwinSnakes,
Constraints are kind of a whole different area of stuff.
Normally a constraint-based program will represent them in the GUI by things like dimension lines, and let you click on the dimensions to change the values and recalculate the shape.
The recalculation can involve quite a lot of detailed stuff like extending certain parts, sliding other parts over, maintaining other constraints at the same time, etc... That involves a constraint solver and that solver part is not something that I have already available. That kind of solver mechanism is a lot different than being able to specify a line length while you draw, when you change the line length in the solver, the solver will make a lot of changes to other pieces of the drawing in addition to the line that was just edited.
I do expect to have a deeper history and parameter editing function in MoI which would let you do things like edit the control points of one of the original curves you drew and then update the model to reflect the changes (this already works to a certain degree) but that is a pretty separate thing from constraints.
I don't really expect to have constraints in MoI for the foreseeable future, that's something that you will need to use a system like SolidWorks, SolidEdge, Pro/E, etc... for that kind of workflow.
2150.30 In reply to 2150.20
Thanks for all the replies, Michael.
It sounds really good ... I look forward (as always) to the next beta.
cheers
eric
2150.31 In reply to 2150.30
The next beta will be launch next week ( I wish :) )
2150.32 In reply to 2150.31
Like, say, 9am, 17 Nov, Ausie Adelaide Time!
Brian
(9.30 is ok!)
I got a method set up for editing the size now...
You can put in expressions like 22/5 in there, and also use a + or - sign at the start to make a relative change in size.
2150.34 In reply to 2150.33
COOL, thank you sir...
2150.35 In reply to 2150.33
Looks very impressive... :)
How about this :
Message 2150.36 deleted 15 Nov 2008 by YANNADA
2150.37 In reply to 2150.35
Hi Michael...
Take a look at this video just for your inspirations...
2150.38 In reply to 2150.37
this last one video is more for "polygon" box modeler ;)
2150.39 In reply to 2150.33
since you can enter +2.5 on Z (whence you had 5); would it be possible to incorporate on any given dimension f(d); where f is a function (+, -, *, /) and d is the dimensional value of X, Y, or, Z? This would allow to generate some geometries with proportions; for instance X could be 2*Z. The difficulty for at least a novice user would be to avoid creating a circular relationship.
Cheers,
- Diego -
2150.40 In reply to 2150.38
Is called Instant3D in Solidworks, It’s an answer to Spaceclaim, CoCreate, Synchronous Technology in Solid Edge and NX, etc. "SketchUp on Steroids" as Deelip Menezes said.
Synchronous Technology is very cool tech which Siemens built on top of the Parasolid. (SolidWorks also is based on Parasolid Kernel) http://www.plm.automation.siemens.com/en_us/campaigns/breakthrough/
http://www.evanyares.com/the-cad-industry/2008/5/21/synchronous-technology-and-design-freedom.html
http://www.synchronoustechnology.net/blog/54/editing-imported-models-the-easy-way/ COOOOOOOOOOL
EDITED: 16 Nov 2008 by YANNADA
2150.41 In reply to 2150.35
Hi Anis -
> How to change 3D model directly from 5 to 7mm
This new system will also allow you edit the size of a sub-object like an edge or a face, like this:
I'll probably also be tweaking that a bit, to show length for a line and radius for a circle, rather than x,y,z bounding information for those particular kinds of objects.
But this new system is for setting the size of the entire object, it will not do "constraint" based type operations that may extend and alter interior regions of a shape differently than the shape as a whole.
That kind of interior part modifying requires a lot different kind of mechanism behind it which I don't expect to have incorporated into MoI anytime soon. For that you should use one of those "direct manipulation" style modeling systems instead, like SpaceClaim, Siemens NX, Kubotek, etc... Or it also sounds like there is some new stuff available in SolidWorks for that as well? At any rate, if you need to do those kinds of operations those other modeling systems will be the proper tool for that kind of a job, not MoI.
Just keep in mind that MoI is not particularly focused on being a complete replacement for one of those kinds of modeling systems. If the things you need to do are solved very well already by one of those other systems, then I generally expect that you should use them for that task and not MoI.
EDITED: 16 Nov 2008 by MICHAEL GIBSON
2150.42 In reply to 2150.39
Hi Diego,
It sounds like you may be talking about setting up some kind of persistent constraint that is enforced through subsequent operations?
That kind of persistent relationship would be quite difficult for me to set up right now.
This tool is a kind of "one shot" scaling mechanism, it does not set up a persistent constraint on an object, just does a direct edit of it.
However, it may be pretty easy for me to make a sub-set of what you are talking about (or maybe this even will directly fit what you want?), which would be to have "x", "y", and "z" variables available to the expression that you type in so that you could enter an expression like: 2 * x for the Y: value. That would edit the shape to have that proportion right then, but not set a persistent relationship. There should not be a problem with cycles since the expression is discarded and replaced by the evaluated numeric result as soon as you push enter.
I'll take a look at that.
2150.43 In reply to 2150.41
YeeeHaaawwww! An old friend has come to MoI.
Just to be sure, where you answered:
It WONT do a single edge? Are points included? Position is next :) !
MoI is SO gui it sticks all over you!
2150.44 In reply to 2150.43
Hi Burr,
Sort of... You can set the length of a particular edge, but it sizes the whole object to get that edge to the size you asked for.
Not currently but I think I can make that work.
2150.45
Well, Michael, I take my eye off the forum for a little while and what do I find? Editable size and viewable directly at the top of the interface!!
Great stuff - just what I was hoping for. Hats off to you, sir!
Tony
Show messages:  1-5  6-25  26-45  46-65  66-85  86-105  …  126-135
