Scene managment....?...
 1-15  …  76-95  96-115  116-135
2150.116 In reply to 2150.113
Thanks Burr! Please let me know if you run into any problems!
2150.117 In reply to 2150.110
Hi Danny, one thing that will probably come in handy for you is that type label in the upper-right corner just to the right of the name.
When you have an object selected that has all joined edges, it will say "Solid" over there so that should be a quick way to tell if your object is a full solid without needing to do any other steps.
That "select naked edges" script will still be handy for the case where you don't have a solid and you want to see where the open edges are, but you won't need to run it just to see if something is a solid or not.
2150.118 In reply to 2150.114
>What about with splitting?
>Currently names will survive that too, with the same name being applied to the split up pieces
>Does that seem bad? It seems like it could be useful.
mmm, not sure at this stage, I guess I have to use it a bit more before I can answer the question.
Thanks again
2150.119 In reply to 2150.118
Hi Danny, yeah really the name is not particularly useful quite yet - it probably won't really be apparent what to do with some of these specifics until the scene browser tree thing is available, which will use the names more heavily I think.
2150.120 In reply to 2150.119
Agree!
2150.121 In reply to 2150.118
Danny,
I'll see you at the next release!!!??? :)
2150.122 In reply to 2150.121
If there is a chance some time Michael, within minutes I am really missing my TWO special things!
(The old ones don't seem to work)
Brian
EDITED: 30 Dec 2008 by BWTR
2150.123 In reply to 2150.122
Brian,
Here is the first one called sidepane.htm (ref #2)
This is placed in the UI folder.
Be sure to back up the original sidepane.htm before you overwrite it with this.
I dont remember what it's supposed to do so I cant test it first. I'm looking at the #1 file now to get that out to you.
Let me know.
Burr
2150.124 In reply to 2150.123
Here is the 2nd one called commandbar.htm
Same proceedure.
[EDIT]
Brian, Sorry it's late and I didnt get it right. I'll try to straighten it out tommorow.
[EDIT]
EDITED: 21 Nov 2008 by BURRMAN
2150.125 In reply to 2150.121
Burr,
I'll be there! don't be late...............again! :D
2150.126 In reply to 2150.125
I suppose in this episode I'm "Eli Wallace"... The heel!
Next time... Clint Baby!
2150.127 In reply to 2150.126
2150.128 In reply to 2150.122
Brian,
Your commandbar and commandbarright files I believe are just reversed but there are some subtle changes in the new beta that I need to look at so it works right. It's late and I've had a couple beers so I'm going to stop here instead of cause more confusion. Check out the new stuff and we'll get you squared away tommorow.
Burr
2150.129 In reply to 2150.128
Hi Burr / Brian - re: deselect part, there are some notes here for how to set that one part up:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1996.13
There is a fair amount of new stuff in the UI in this beta release, so you can't just copy an older version's UI file over top of it or else you'll lose all the new stuff.
Because each beta is kind of a changing and moving target, I'd generally recommend holding off on customizations until v2 is all wrapped up and isn't in flux anymore. But of course you're more than welcome to give it a try if you want - I just won't really be able to focus on it very much myself until things have stabilized.
I have quite a lot of notes on the new beta, it will take me until tomorrow to get them all straightened out.
So tomorrow I'll put out a proper notice post with all the notes.
A new rock song is born ;=)
2150.132 In reply to 2150.131
Thanks Burr/Michael
Burr---I won't play with that SidePane zip yet--just in case!
Brians Bottom Edge UI
It seens so natural to use for me that I wonder how anyone is happy with the default!
The message--- I hope I don't have to wait untill well into next year. I would go balmy(ier)
Time I went to bed.
Thank you both.
Brian
2150.133 In reply to 2150.132
Brian,
The sidepane file I posted is fine and works. You can get that loaded. Am looking at the other 3 files now to see if the toolbar config will go.
2150.134 In reply to 2150.122
Brian,
Here are 3 files that would go into the ui folder.
It's the best I could do. Its all the same except that I couldnt get the input, options and help to move over to the right, so it all stays bunched up on the left.
In the same order but not exactly how you had it.
I think michael is right as this is an area that is having alot of change. It's only going to get worse from here on out. Best to wait till the version is released and then Michael will set it up for you. Just a short annoyance for a great product in the end.
Unless someone else with better skills than I in this area wants to look at these files and make the space happen.
Remember, you can always try these without worry if you rename the existing ones before copying them in. I always just append "old" to the existing name so its easy to revert by just deleting the new files, then finding the renamed originals and changing the name back again.
Good luck,
Burr
[EDIT] The zip file was edited so if you visited this file before you saw this, you must redo the process again[EDIT]
2150.135 In reply to 2150.134
Thanks Mate.
Brian
Show messages:  1-15  …  56-75  76-95  96-115  116-135
