Fillets again
 1-4  5-23
2148.5
Hello again
Two rendertests with my way to fillet some edges. In my opinion the sample from PaQ looks really better. Seems to be very difficult to decide the ride way. I'm curious about on PaQ workflow.
Greetings from Munic
(you know the "Münchner Kindl"? )
Size: 67.9 KB, Downloaded: 23 times, Dimensions: 800x600px
2148.6
Yes PaQ! A video would be fantastic. I also struggle with filleting and have to confess that I avoid MoI if I have to fillet stuff.....
Rainer
2148.7 In reply to 2148.6
Hello there, the video is uploading on screencast, I did my best to avoid mistakes, but it wasn't easy :) ... moreover the capturing session is limited to 5 min, and that was short to fillet everything in that time, so I have to speed up.
In the meantime, I've just seen that one g1 fillet is broken, looks like an othe continuity lost like here :
http://moi3d.com/forum/index.php?webtag=MOI
@Apophis
Nice rendering ! and no I don't know what a Münchner Kindl is ... (is it something related to the famous beer party ?)
http://www.lespassionnes.fr/photos/evenement_60.jpg
EDITED: 3 Dec 2015 by PAQ
2148.8 In reply to 2148.6
Hi Lemo, what else are you using then ?
I don't have a lot of experience with nurbs, and most of the time when I have to fight against MoI fillet, I win ...
But for any reason if it's really impossible to find a solution for a precise scenario, I didn't find that other softwares like viacad were that helpfull :S
2148.9
2148.10
A very detailed tutorial. I guess that this tutorial will not only me help to understand the work with fillet. Great job PaQ.
Many Thanx.
@PaQ : What is your prog for make the video?
2148.12 In reply to 2148.11
its made with jing
nice one PaQ
www.max3d.org
2148.13
You're welcome Apophis ;)
Yes Pilou it's Jing, I like the video quality, but you can't control anything about it, like the framerate or the format.
This 5 minutes limitation is also quite annoying, and they are no edition option too :(
Still looking for an cheap solution to make quick videos ...
2148.14 In reply to 2148.13
< Still looking for an cheap solution to make quick videos ...
there is Wink it's 100% free and you can make any tutorial as you want!
http://www.debugmode.com/wink/
Generate Flash files
A little example :) (launch the file fomat .htm in your navigator)
http://www.mediafire.com/?yjqzyk3cdyy (seems mediafire have some trouble today ;)
And after with the free Converter online http://media-convert.com/convertir/
you can make any format you want !
Here in format Quick time
http://www.mediafire.com/download.php?ztbg5oonwdy
I try to embed the result here so making some try :) be patient :)
I found some cool tools for create automatically the code of Embedded (Flash, Real, QuickTime, Wmv)
http://cit.ucsf.edu/embedmedia/step1.php
http://tools.webmasters.sk/embedded-media.php
Here with SWF format and streaming result
and the Quicktime format ;) (some speedy because maybe I have forgotten a speed regulate at the conversion :D
EDITED: 12 Nov 2008 by PILOU
2148.15
Hello
Is there a possibiltiy to get PaQ's video offline? It's very difficult to look and to work with only one screen.
2148.16
Resume
My work is done :-)
Step by step with fabulous description.
Two questions stay. First the image below. The edges in the middle ( red arrow ) couldn't be used with fillets. I don't know why, because there are the same edges like in PaQ's Turtorial.
I've a suspicion. My workstation
(Computer Intel(R) Core(TM)2 CPU 6420 @ 2.13GHz 2.05 GHz, 2,00 GB RAM with Winxp seems to be overstrained. Is MoI developed for dual core processor? Any activity with bigger meshes work very slow. If I compare my MoI and the application from PaQ there are many differences.
Michael
2148.17 In reply to 2148.16
Hi Apophis,
First for you performance problem, check this in the options settings :
- Unchecking the 'add detail to inflections' will boost MoI.
I don't think MoI is multithreaded for the moment, so you should have mostly the same speed as in the video (quad 3.0 here).
For the fillet problem, it's a question of sequence to respect :
The edge you're pointing should be filleted before the side surface.
(You can still correct it, I can create an other quick video this evening)
For the offline video, I have to check how I can do that using the screencast service.
2148.18 In reply to 2148.14
Thanks Pilou, Wink seems to create nice video too. I Will have a look at this this evening, I hope it's possible to edit the movie after recording (I moslty need some cutting tool).
2148.19 In reply to 2148.18
Of course yes you can edit anything ;)
Key delete is your friend :)
2148.20 In reply to 2148.15
Right click and "save target as"... Play with browser on local machine.
http://www.exeink.com/caps/rip/full_pump.swf
Screen cast pumps it out as a "50 MB" file. Trying to re-encode it now to bring the size down.
[EDIT]
Gave up on trying to re-encode it. If you want it locally download the 50 mb file.
It wont be there forever! at least a few weeks.
Some browsers wont play the native flash file. I've attached an html file that will play the flash video. It must be in the same place as the flash file.
[EDIT]
2148.21 In reply to 2148.20
Thanks a lot for the hosting BurrMan, my screencast bandwidth limit is allready over.
I definively have to find a better compression solution.
2148.22 In reply to 2148.21
I think that the jing screencast thing doesnt give much control of that. thats what the paid versions give is more control of the output. The original capture could be much smaller, but to "grab" what screencast pushes down was not an acceptable solution.
2148.23 In reply to 2148.22
Looks that jing project it's just an advertising for screencast service, since yesterday I allready get 5 mails about bandwidth limit :S
Show messages:  1-4  5-23
