How to fillet/chamfer text ?
All  1-6  7-17
2144.7 In reply to 2144.6
PaQ its jing, you can download it from here http://www.jingproject.com/ you can use the embed code or link to the file and its free. its made by the makers of snagit etc
2144.8 In reply to 2144.7
Thanks, I'm download it right now as my camtasia demo is over.
2144.9 In reply to 2144.8
It's more a test than a real tutorial capture, even it's how I fillet text.
As a rule I fist fillet extruted edges that are >= of 90° ... I could fillet the letter at once, but by doing that I don't change the font 'design' too much.
@Max,
How do I embeded the video in my message ?
EDITED: 8 Nov 2008 by PAQ
2144.10 In reply to 2144.9
you hit the embed icon which is next to the share icon. it will copy the embeded code to your clipboard and my name is dave :)
www.max3d.org
2144.11 In reply to 2144.1
Hi Jumbo - like PaQ mentioned you can select the front face to fillet all the edges attached to it which is a nice shortcut for this kind of thing.
And if you want to fillet all edges, you can do that by selecting the whole object instead of individual edges.
Text can often have situations like very sharp pointed corners and tightly bent curves which can make for difficult filleting situations. Like you saw, it is pretty easy to ask for a fillet that will not fit in the given area because of going around a bend. So it is usually a good idea to also try smaller values and see if that will give you a result.
2144.12 In reply to 2144.10
Sorry Dave :)
(in fact my question is, how do I add the link inside MoI forum, so we don't see the url but only the video ? )
2144.13 In reply to 2144.12
Hey Paq,
If the url you post is the "Embed" link then it just shows up as video.
2144.14 In reply to 2144.12
Hi PaQ,
There will usually be some kind of snippet of HTML code that is available for you to copy.
If you copy that and paste it into your forum message here, it should make the player show up directly inside of your message.
See http://moi3d.com/forum/index.php?webtag=MOI&msg=2042.25 for an example from screencast.com .
The HTML code will start with either <object> or <embed>
2144.15 In reply to 2144.14
indeed if you click on the "<>"icon it will produce a code (long one) this is copied automatically to your clipboard by jing and all you do then is paste it into your message window as is and it will show as a video window. hope that helps
www.max3d.org
2144.16 In reply to 2144.15
Hi Dave and Michael,
Ok, it's working now, thanks for your help
2144.17 In reply to 2144.16
no worries mate
www.max3d.org
Show messages: All  1-6  7-17
