Smooth transition
 1-2  3-22  23-42  43-62  63-68
2140.43 In reply to 2140.42
2140.44 In reply to 2140.43
Burr
Thats not fair!
Now, the HOW in MoI!
Brian
2140.45
@ Burr
> I'm getting very close! :o
lol That's a cracker abstract what do you call it ? :)
@ PaQ
> Love this kind of game, it only takes me 1 hour haha :P
Yeah, going through the forum lately, not enough modelling going on :-o, so I thought I'd throw this challenge in for a stir up, I'll see if I can post some more like this, or anyone else.
Done a quick render of Fredrik's challenge that you tackled, good one Fredrik !, the transitions look nice (attached)
@ Brian
> Being sarspreditious,......
sarspreditious ??? is this a Brian word, looked it up can't find it !
2140.46 In reply to 2140.42
> the thought is of the potentials if MoI could produce a Polyhedron?
Hi Brian, here is a method for that:
Start by drawing a central polygon with Draw curve / Polygon / Center, then draw the 2 connected ones by Draw curve / Polygon / Edge
Then you want to rotate that polygon up along its edge, which you can do by using Transform / Rotate / Rotate axis.
But you need to get a snap point for the proper angle, so to do that you set up 2 vertical circles that trace the path of rotation and you can find the angle as a snap point where they intersect.
Once you have rotated one up, delete the circles and the other flat polygon, and use Transform / Array / Circular with 5 items to produce the other sides. You can use Construct / Planar to make planar surfaces out of all the polygons.
That constructs have of it, you can then mirror and do a Transform/Rotate to make the second half into place.
EDIT: also attached Dodecahedron.3dm finished model file.
2140.47 In reply to 2140.46
Michael and all
Who could not love this forum!
Danny. "Sars---"--having used it I looked it up in the (many) dictionaries--could not find! It was a word my Mother, born 1890s, used regularly. It means "thats being a pain in the "neck" in an argument/discussion " (pita)
Another one, from my wife and her female cousins. "bonkerinka holders"---any thoughts?
Gotta laugh!
Brian
2140.48 In reply to 2140.46
I was trying to figure out how to get that rotation!
Thanks.
2140.49 In reply to 2140.44
Brian,
Thats from an old post of a Blender guy asking how to do a 4 sided rounded pyramid.
I'll find the link to the thread and post back.
It's not my original work! (It's mine but I was just following along here.)
Burr
2140.50 In reply to 2140.45
Thanks Danny, I call it "Cerebral overclocking!"
By the way, Your renders are enviable.
Very nice!
2140.51 In reply to 2140.49
Hi Burr, I think this is the thread you are referring to:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1782.1
2140.52 In reply to 2140.51
Yes thats the thread.
After it was all said and done I liked the way MG did it with "Larger Sweep Sheets" and trimmed together. Thats what created the model I just posted.
Burr
2140.53 In reply to 2140.46
Michael,
Is there a name for the intersection or method you created with the two circles for the Dodecahedron? I will be studying this a bit and would like to go a little deeper with some googleing/wikipedia stuff.
Burr
2140.54 In reply to 2140.42
How about an icosahedron?
That is produced using 3 planes for construction
- Steve
EDITED: 3 Aug 2009 by MANZ
2140.55
Not as much fun as trying to build it yourself ... but for reference, check out
http://www.rhino3d.nl/pythposter/pyth3dm-eng.html
all .3dm files
cheers,
eric
2140.56 In reply to 2140.54
Thanks Steve.
These are the times when one wishes the simple constructions of polyhedron options in the Carrara Vertex Room could be saved to bring into MoI!
Brian
EDITED: 30 Dec 2008 by BWTR
2140.57 In reply to 2140.56
Eric
What a great site! All saved into my MoI file saves recources! Thanks.
Brian
2140.58 In reply to 2140.56
If you want to mess around with polyhedra, you can save off of Rinus Roelofs' model files from that link that Eric posted:
Then when you want to bring one into your current project use File / Import to load it into your current file.
EDIT: Looks like you figured that out already! :)
2140.59 In reply to 2140.53
Hi Burr,
I'm not really aware of any special name for that method... I would call it a kind of "geometric" solution since it is setting up additional geometry to intersect to find the right point.
For more information you might try googling "platonic solids". You'll probably find some other methods that calculate what the various angles have to be for the pieces to meet exactly.
2140.60 In reply to 2140.59
Eric/Michael
For interest
Those polyhedron files do not Thumbnail--as do not MoI 3DM files!
Brian
2140.61 In reply to 2140.60
> For interest
They were possibly saved from Rhino using the "Save small" function which tries to reduce the amount of stuff stored in the file.
If you want to get Thumbnails, save them from Rhino without using Save small and that should make a thumbnail image inside the file.
2140.62 In reply to 2140.61
Michael
I only have the demo of Rhino.
The thought of having to take MoI files, via Rhino, to save them out with the thumbnail???
Something for the MoI wish list?
Brian
Show messages:  1-2  3-22  23-42  43-62  63-68
