Smooth transition
 1-14  15-34  35-54  55-68
2140.35 In reply to 2140.34
Oh
Is doesn't want to shell. It's this little surface that seems to stop the shelling:
-Fredrik
2140.36 In reply to 2140.35
Funny! This surface i was able to shell in Rhino, and then i pasted it back into moi and bool'ed it together into a solid (couldn't bool it in Rhino).
Just show how complementary Moi and Rhino are: if you can't do it in Moi, you can in Rhino, and vise-versa ;)
- Fredrik
2140.37 In reply to 2140.36
Here's another task:
who dares to try ?
-Fredrik
2140.38 In reply to 2140.37
I haven't used moi in a while, but here's my attempt. Only the network part is needed.
Network doesn't work well in this case. I don't know exactly why. Probably because it needs 4 edges to create a 'squarish' patch.
So it's better to select two of the edges, and blend them. Then trim the result with the 3rd edge.
EDITED: 8 Nov 2008 by ANTHONY
Size: 79.3 KB, Downloaded: 83 times, Dimensions: 900x699px
2140.39 In reply to 2140.38
I'm getting very close! :o
2140.40 In reply to 2140.39
Excellent Mister BurrMan =o)
What about this one ?
Love this kind of game, it only takes me 1 hour haha :P
EDITED: 3 Dec 2015 by PAQ
2140.41 In reply to 2140.40
Since Anthony already hit it out of the park...Just trying to be overly analytical.
The spike object is a G2 of all the centerpoints and the flower looking object is comprised of the curves extracted from a merge of the intersection area.
Just a way I contemplate all the possibilities!
Funny out of this I have gotten practice at alignment and rotation. It's all good
2140.42 In reply to 2140.41
I like that Burr!
Being sarspreditious, as usual, fiddling with another way to get my heart stransplant working, the thought is of the potentials if MoI could produce a Polyhedron?
Brian
EDITED: 31 Dec 2008 by BWTR
2140.43 In reply to 2140.42
2140.44 In reply to 2140.43
Burr
Thats not fair!
Now, the HOW in MoI!
Brian
2140.45
@ Burr
lol That's a cracker abstract what do you call it ? :)
@ PaQ
Yeah, going through the forum lately, not enough modelling going on :-o, so I thought I'd throw this challenge in for a stir up, I'll see if I can post some more like this, or anyone else.
Done a quick render of Fredrik's challenge that you tackled, good one Fredrik !, the transitions look nice (attached)
@ Brian
> Being sarspreditious,......
sarspreditious ??? is this a Brian word, looked it up can't find it !
2140.46 In reply to 2140.42
Hi Brian, here is a method for that:
Start by drawing a central polygon with Draw curve / Polygon / Center, then draw the 2 connected ones by Draw curve / Polygon / Edge
Then you want to rotate that polygon up along its edge, which you can do by using Transform / Rotate / Rotate axis.
But you need to get a snap point for the proper angle, so to do that you set up 2 vertical circles that trace the path of rotation and you can find the angle as a snap point where they intersect.
Once you have rotated one up, delete the circles and the other flat polygon, and use Transform / Array / Circular with 5 items to produce the other sides. You can use Construct / Planar to make planar surfaces out of all the polygons.
That constructs have of it, you can then mirror and do a Transform/Rotate to make the second half into place.
EDIT: also attached Dodecahedron.3dm finished model file.
2140.47 In reply to 2140.46
Michael and all
Who could not love this forum!
Danny. "Sars---"--having used it I looked it up in the (many) dictionaries--could not find! It was a word my Mother, born 1890s, used regularly. It means "thats being a pain in the "neck" in an argument/discussion " (pita)
Another one, from my wife and her female cousins. "bonkerinka holders"---any thoughts?
Gotta laugh!
Brian
2140.48 In reply to 2140.46
I was trying to figure out how to get that rotation!
Thanks.
2140.49 In reply to 2140.44
Brian,
Thats from an old post of a Blender guy asking how to do a 4 sided rounded pyramid.
I'll find the link to the thread and post back.
It's not my original work! (It's mine but I was just following along here.)
Burr
2140.50 In reply to 2140.45
Thanks Danny, I call it "Cerebral overclocking!"
By the way, Your renders are enviable.
Very nice!
2140.51 In reply to 2140.49
Hi Burr, I think this is the thread you are referring to:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1782.1
2140.52 In reply to 2140.51
Yes thats the thread.
After it was all said and done I liked the way MG did it with "Larger Sweep Sheets" and trimmed together. Thats what created the model I just posted.
Burr
2140.53 In reply to 2140.46
Michael,
Is there a name for the intersection or method you created with the two circles for the Dodecahedron? I will be studying this a bit and would like to go a little deeper with some googleing/wikipedia stuff.
Burr
2140.54 In reply to 2140.42
How about an icosahedron?
That is produced using 3 planes for construction
- Steve
EDITED: 3 Aug 2009 by MANZ
Show messages:  1-14  15-34  35-54  55-68
