Smooth transition
 1  2-21  22-41  42-61  62-68
2140.22 In reply to 2140.21
That's ok Michael as long as those things are in the pipeline, and we know how long the Transcontinental Pipeline is ;) but we can wait as MoI is already a productive piece.
2140.23
Yeah, Paq's method works like'a charm. I even did a shell and it's perfect.
2140.24 In reply to 2140.7
Hi Anis,
>I dont know how to create those shape in moi
Thanks for the demo, is it possible to post an iges, step or .3dm of the Solidworks result so we could have a closer look ?
2140.25 In reply to 2140.24
HI Michael, Danny...
Here is what you want.... :)
2140.26 In reply to 2140.25
Hi Anis,
If you examine your SolidWorks result with Zebra stripes across the whole model (instead of only on that one single patch itself), you can see the same kind of zebra line breaks in it, just in a different location where the patch touches the straight parts.
Again though - that does not mean that it is totally discontinuous there - because the zebra stripes line up it means there is tangent continuity there.
2140.27 In reply to 2140.26
If you examine that same area with the MoI generated model using PaQ's method, it looks like this:
That same area is very nice with this method.
But instead you get the tangent-only area in a different location - where the top plane touches the blends.
I would think the best compromise shape would probably be to do those side blends but only about 3/4 of the way towards the top instead of all the way to the top. Then fill in the remaining area with an N-sided patch or "fill" instead of trying to fill such a larger area with it.
2140.28 In reply to 2140.26
Hi Michael....
Yeah, thanks for checked it....
BTW after object organization done, have you a plan to add some surface or modeling tool for V2 ?
-anis
2140.29 In reply to 2140.28
Hi Michael...
Correct, PaQ method looks better on those area.
So, it will very useful to have fill surface inside moi in the feature.
Network have limitation on making tangency....
2140.30 In reply to 2140.28
Hi Anis,
Currently I plan to do a bunch of work on the sweep tools to make those better.
I don't think it is too likely that I will be able to get any brand new surfacing tools in for v2 though. Maybe variable radius fillet, but it depends on how difficult it will be to get a nice UI for that.
2140.31 In reply to 2140.30
I did the middle network bit first and then did simple sweeps.
Would that be ok as well?
Brian
EDITED: 31 Dec 2008 by BWTR
2140.32 In reply to 2140.31
It will give a very similar result...
But if it is a goal to ensure smoothness to adjacent surfaces, then Blend can work better for that since it does additional work to create a smooth result the edges that it is given.
2140.33 In reply to 2140.32
I know there are some odd things in my MoI file but, for my level of accuracy it seemed fairly adequate..
Brian
2140.34 In reply to 2140.33
Hi I see PaQ already solved this,
Anyways, I made an attempt using Rhino, and it seems to work with Curvature continuity on one side and tangency/nearly curvature in the "inner bend"
The inner bend curve is split in the middle, at the kink in the top curves. It looks like the "swx" patch isn't flat at the top, a thing one would sometimes want.
This one is at least flat at the top.
The control points:
Interesting problem and typically difficult .) I tried T-splines on it, but it seems to give a melting effect, yeah. But I may not have found the optimal way in TS yet.
Regards,
Fredrik
EDITED: 8 Nov 2008 by FREDRIKW
Size: 40 KB, Downloaded: 24 times, Dimensions: 925x458px
2140.35 In reply to 2140.34
Oh
Is doesn't want to shell. It's this little surface that seems to stop the shelling:
-Fredrik
2140.36 In reply to 2140.35
Funny! This surface i was able to shell in Rhino, and then i pasted it back into moi and bool'ed it together into a solid (couldn't bool it in Rhino).
Just show how complementary Moi and Rhino are: if you can't do it in Moi, you can in Rhino, and vise-versa ;)
- Fredrik
2140.37 In reply to 2140.36
Here's another task:
who dares to try ?
-Fredrik
2140.38 In reply to 2140.37
I haven't used moi in a while, but here's my attempt. Only the network part is needed.
Network doesn't work well in this case. I don't know exactly why. Probably because it needs 4 edges to create a 'squarish' patch.
So it's better to select two of the edges, and blend them. Then trim the result with the 3rd edge.
EDITED: 8 Nov 2008 by ANTHONY
Size: 79.3 KB, Downloaded: 83 times, Dimensions: 900x699px
2140.39 In reply to 2140.38
I'm getting very close! :o
2140.40 In reply to 2140.39
Excellent Mister BurrMan =o)
What about this one ?
Love this kind of game, it only takes me 1 hour haha :P
EDITED: 3 Dec 2015 by PAQ
2140.41 In reply to 2140.40
Since Anthony already hit it out of the park...Just trying to be overly analytical.
The spike object is a G2 of all the centerpoints and the flower looking object is comprised of the curves extracted from a merge of the intersection area.
Just a way I contemplate all the possibilities!
Funny out of this I have gotten practice at alignment and rotation. It's all good
Show messages:  1  2-21  22-41  42-61  62-68
