Fruit and Vegetables
 1-4  5-24  25-44
2115.5 In reply to 2115.4
And another one.
Brian
EDITED: 31 Dec 2008 by BWTR
2115.6 In reply to 2115.5
Broccoli
Only part way through just the Broccoli head and running out of MoI/Computer limits!
Maybe I am too ambitious
Brian
2115.7 In reply to 2115.5
Nice work
You will be the first farmer to harvest
on the planet Mars
2115.8
A banana :-)
1.- Draw a hexagon and an arc
2.- Sweep the hexagon with the arc like rail, and care to finish both ends in point
3.- For cutting the ends, draw 2 lines and fuse them with the solid. After that, you can separate the result
4.- Fillet it and...a banana! :-)
EDITED: 28 Oct 2008 by DAVID
2115.9 In reply to 2115.8
nice!
2115.10 In reply to 2115.9
Good one David.
Lots of learning I am finding out. Skills build up and become usefull for later more complex work.
Brian
2115.11
Thanks steve and Brian!
Now, a pumpkin :-)
1.- Draw a 10 points star
2.- Fillet all the vertex
3.- Draw the axe of the shape.
4.- Draw a freeform curve with control points. Keep the tangent with the 2 first points
5.- Finish the curve in the axe
6.- The same for the bottom "hemisphere"
7.- Rail revolve
8.- The same in the bottom....
9.- A pumpkin!
10.- Take a set of eyes and mouth for halloween. Use the booleans for draw the face :-)
2115.12
A few more guys and we could assemble a fruit salad :D
2115.13 In reply to 2115.12
Great David.
Good fun!
Here is my little effort for this morning.
Brian
2115.14 In reply to 2115.13
David
One of the things I have in Carrara can, I think, produce little round bumps all over the surface--actually in 3d displacement! Guess you have seen those sort of small pumpkin type things.
Any chance of having your 3DM file to try rendering on please?
Brian
2115.15 In reply to 2115.11
Hey David you've done this before!
Great how-to, thanks.
And Brian, your veges have been genetically modified I'm sure
2115.16 In reply to 2115.15
Steve
I am just working from "memory"!
(My wife would say WHAT memory of kitchen stuff!)
TRUE!
Brian
2115.17
@Brian: I didn´t save the file because it was very basic. The idea was to show like with a poweful tool like MoI you can make pretty things with a few steps (obviously, the final model may be more refined). But I have made it again and I have seen that is not necesary to divide the profiles in two "hemispheres" (less steps) :-)
You get a very nice renders, I´ll be grateful for your render.
@steve: anything like that? :-P
Size: 246.9 KB, Downloaded: 74 times, Dimensions: 413x533px
2115.18 In reply to 2115.17
David
I hope you like this. A good bit of fun.
All the rendering in Carrara6Pro.
Brian
2115.19 In reply to 2115.17
Hi David, this picture of the watermelons is great. I assume that's something you did in Photoshop??
2115.20 In reply to 2115.1
A quick play with a cabbage leaf.
EDITED: 3 Aug 2009 by MANZ
2115.21 In reply to 2115.20
Just too, too clever mate.
NOW, you must explain how you did it!
Please!
Brian
2115.22
Hi Michael and Friedns
This is an exercise that I have made approximately a year makes in occasion of Hallowin,
that I have sent to the Forum of the Tspline Program Plug-in of Rhino
The images that you see are renderizzate with Rhino Render
without the application of texture or bump-
This that you see and the resolution of the superfaces ones obtained,that they can be imported in moi from Rhino-
All the built of the shapes has been made in poligonal and translate in Ts-Surface-
For the realization of the organic shape, especially vegetables, as in this case , Plug-in Tspline it is a unparalleled instrument
I augur myself that in future this Plug-in it can in some way
it can be implemented in this program-
best
al
Sorry for my bad english
Size: 244.5 KB, Downloaded: 25 times, Dimensions: 1024x768px
Size: 268.9 KB, Downloaded: 57 times, Dimensions: 1466x1015px
Size: 121.7 KB, Downloaded: 43 times, Dimensions: 800x600px
2115.23 In reply to 2115.21
>>NOW, you must explain how you did it! Please!
Very simply for that model
Create a sphere. Then in one of the 2d views draw the curves for the pattern of the veins:
Project those curve to the sphere surface. (you could of course of drawn those directly to surface if wanted in V2)
Sweep circles (or whatever shape you think best) on the surface curves with the "pointy end" option.
Once done, you can then trim the sphere in half, and boolean the main vein.
Using a control point curve, start at one of the intersections then draw using "on surface" snap the shape of the outside of the leaf, then finish the curve at the other intersection (as next pic)
Using the drawn curve, trim the sphere.
Hope I have explained OK.
- Steve
2115.24 In reply to 2115.23
Easier said than done though I think.
Will do/try to emulate today.
Brian
Show messages:  1-4  5-24  25-44
