Fruit and Vegetables
 1-16  17-36  37-44
2115.17
@Brian: I didn´t save the file because it was very basic. The idea was to show like with a poweful tool like MoI you can make pretty things with a few steps (obviously, the final model may be more refined). But I have made it again and I have seen that is not necesary to divide the profiles in two "hemispheres" (less steps) :-)
You get a very nice renders, I´ll be grateful for your render.
@steve: anything like that? :-P
Size: 246.9 KB, Downloaded: 74 times, Dimensions: 413x533px
2115.18 In reply to 2115.17
David
I hope you like this. A good bit of fun.
All the rendering in Carrara6Pro.
Brian
EDITED: 31 Dec 2008 by BWTR
2115.19 In reply to 2115.17
Hi David, this picture of the watermelons is great. I assume that's something you did in Photoshop??
2115.20 In reply to 2115.1
A quick play with a cabbage leaf.
EDITED: 3 Aug 2009 by MANZ
2115.21 In reply to 2115.20
Just too, too clever mate.
NOW, you must explain how you did it!
Please!
Brian
2115.22
Hi Michael and Friedns
This is an exercise that I have made approximately a year makes in occasion of Hallowin,
that I have sent to the Forum of the Tspline Program Plug-in of Rhino
The images that you see are renderizzate with Rhino Render
without the application of texture or bump-
This that you see and the resolution of the superfaces ones obtained,that they can be imported in moi from Rhino-
All the built of the shapes has been made in poligonal and translate in Ts-Surface-
For the realization of the organic shape, especially vegetables, as in this case , Plug-in Tspline it is a unparalleled instrument
I augur myself that in future this Plug-in it can in some way
it can be implemented in this program-
best
al
Sorry for my bad english
Size: 244.5 KB, Downloaded: 25 times, Dimensions: 1024x768px
Size: 268.9 KB, Downloaded: 57 times, Dimensions: 1466x1015px
Size: 121.7 KB, Downloaded: 43 times, Dimensions: 800x600px
2115.23 In reply to 2115.21
>>NOW, you must explain how you did it! Please!
Very simply for that model
Create a sphere. Then in one of the 2d views draw the curves for the pattern of the veins:
Project those curve to the sphere surface. (you could of course of drawn those directly to surface if wanted in V2)
Sweep circles (or whatever shape you think best) on the surface curves with the "pointy end" option.
Once done, you can then trim the sphere in half, and boolean the main vein.
Using a control point curve, start at one of the intersections then draw using "on surface" snap the shape of the outside of the leaf, then finish the curve at the other intersection (as next pic)
Using the drawn curve, trim the sphere.
Hope I have explained OK.
- Steve
2115.24 In reply to 2115.23
Easier said than done though I think.
Will do/try to emulate today.
Brian
2115.25 In reply to 2115.19
Hi steve:
This picture is real. They develop the watermelons into a box, and obligate them to get this shape. :-)
2115.26 In reply to 2115.18
Hi Brian:
What a nice render. And you have improved the model a lot of! I like the leafs and the stalk very much!
What about a nice render with a helloween theme? :-)
(well I see that speedy has made a nice helloween model yet!)
EDITED: 30 Oct 2008 by DAVID
2115.27 In reply to 2115.23
Good model, and very clever method!
I like very much. The salad is growing :-)
2115.28 In reply to 2115.27
Manz
I hope you enjoy this first, rough, effort with you ideas.
Great fun!
Good, also, to see others enjoying the learning principles involved.
Now it's the Cauliflower and the Broccoli!
Brian
2115.29 In reply to 2115.28
I see you have the idea, and the render is looking good.
I have had one last play with this as I wanted to see if I could get a more organic shape. I have not added too much detail, as I want to move on to some projects I wanted to start a while ago.
- Steve
2115.30 In reply to 2115.29
Hi Steve
Progressing from a cabbage leaf to a lettuce leaf!
Must put somemore time into this idea.
Brian
2115.31
Ok, I couldn't resist ! I had to contribute to this crazy thread :)
EDITED: 27 Mar 2009 by DANTAS
Size: 174.1 KB, Downloaded: 58 times, Dimensions: 800x800px
Size: 69.5 KB, Downloaded: 51 times, Dimensions: 872x684px
2115.32 In reply to 2115.31
Oh!--what great big teeth you have!
Crazy thread?--well guess who started it, what else would you expect!
Brian
2115.33 In reply to 2115.32
The cauliflower head, trying to get a small file size, is a problem.
Here is one poor result, from a MoI file, with some Carrara texturing.
All ideas welcome.
Brian
2115.34 In reply to 2115.33
Danny
I could not resist either!
Here is just a bit of quick render fun of your apple in Carrara6 Pro.
Brian
2115.35 In reply to 2115.34
More on Cauliflower.
This image shows what can be done with Surface Replication in Carrara.
Is this working method one that has potential to be added to say the MoI Array options?
I use it a lot in Carrara. It would be a great option in MoI.
Brian
2115.36 In reply to 2115.35
More Cauliflower.
Still not particularly exciting, but showing using the Carrara Replicator to produce the core piece.
Brian
Show messages:  1-16  17-36  37-44
