MoI Exercise #4 Consumer Product Design --> Colander
 1-10  11-30  31-50
2096.31 In reply to 2096.30
Hi All...
I wish forum member that participate on the moi exercise will be grow up.
Please post your wip or another ideas on this colander exercise. This exercise will be close after oct 31 2008.
Then I need your advice or ideas for the November MoI Exercise.
Just post your image.
The rules is :
1. One image per member
2. Model cant contains more than 10 parts ( base on our experience is previous exercise, too many parts = less participant )
3. Michael G. will choose one of the image for the next exercise by oct 30 2008
I wish all the forumm member agree with this rules.
Too many images and vote will take longer time. So we need this rules.
Many thanks for participate ;)
Regards,
Anis
2096.32 In reply to 2096.31
Anis
First I did a Curve Array and then a Circular Array of that result.
Hope the attached is self explanatory.
Brian
EDITED: 31 Dec 2008 by BWTR
2096.33 In reply to 2096.32
very clear brian... ;)
2096.34 In reply to 2096.31
OK I think I give up now.
This is my best so far. Loft using the curves shown.
The surface is clean and looks Ok but no matter what I try, I cannot get shell to work.
So maybe I'm barking up the wrong tree.
2096.35 In reply to 2096.34
For me, just creating a copy, moving it down a fraction, then creating a sweep profile between the two seemed pretty simple--and just as quick?
Brian
2096.36 In reply to 2096.35
Hi Brian
It doesn't work in this case. First off, it would have to be copy|scale|shift. But the problem is the lower part would need to be scaled up and the upper part scaled down!! Tricky.
2096.37 In reply to 2096.36
Steve
No, no scaling involved. Just a simple copy/paste and lowering the copy a fraction was all that was needed.
Very simple.
Brian
2096.38 In reply to 2096.37
Hi All.....
Just reminder, please post your image for November exercise before Oct 30 2008 ;)
2096.39 In reply to 2096.37
Apologies Brian you are quite right. The secret is to shift down not up! And what is more, the union of the 3 surfaces happens easily and the edges can even be filleted!!
I may be free of this colander yet!
2096.40 In reply to 2096.39
Hi All....
Below is my image for the November exercise. The exercise / challenge is build the 3D bill.
How about you ? Post it !!! ;)
Come on guys.....
EDITED: 19 Jun 2010 by ANIS
Size: 35.4 KB, Downloaded: 27 times, Dimensions: 480x640px
Size: 43 KB, Downloaded: 22 times, Dimensions: 640x480px
2096.41 In reply to 2096.40
Anis
I sidetracked myself on the Fruit and Veg thread!
This is an interesting exercise I think--I am in Oct 29th--can I start now?
Brian
2096.42 In reply to 2096.31
OK here is my image of the colander. Now that I know how to do it, I should start again to get it pretty. But that is not going to happen.
Simplest method I could find. Create profile curve | revolve | pull points around to shape the rim
2096.43 In reply to 2096.42
Thats great Steve--BUT, why not get it pretty? It all adds to the learning!
Anis
Just a quick Duck Bill attempt---getting the "grin" though?
What fun!
Brian
2096.44 In reply to 2096.43
I agree Brian but...no time!
2096.45 In reply to 2096.44
Anis
Could a shape like this work to boolean the Duck mouth shape?
Brian
2096.46 In reply to 2096.42
Hi Steeve...
For this colander exercise, I think your method is best and fastest :)
Good Job !!!
2096.47 In reply to 2096.45
I am not yet start build the duck mouth.
Back to you later in the next exercise .
2096.48 In reply to 2096.46
Thanks Anis, yes the method is OK, but I spent all the time trying to get the method right, then no time left to get the object perfect!! But I haven't seen your final entry?
I learned a lot from this shape so I will show the method in case it is useful to someone:
Draw the first profile and revolve
Top view, show points, scale two selected points from centre
Front view, move two selected points down
This surface will not shell (see http://moi3d.com/forum/index.php?webtag=MOI&msg=2117.4)
So workaround discovered by DannyT, cut it in half then shell, then fillet edges
Also thanks to Danny, delete the two selected surfaces
Then mirror/copy and boolean union.
Voila:)
2096.49 In reply to 2096.48
That was good Steve!
More learning.
And, more ducks bill because I had to!
A different way.
Brian
2096.50 In reply to 2096.48
Hi Steeve....
You can download here :
http://moi3d.com/forum/index.php?webtag=MOI&msg=2096.27
Hey Steeve, Brian...
Thanks for participated on October MoI Exercise.
I am sure this exercise useful for us and others forum member.
Lets wish more participant on the November Exercise !!!
- Anis
Show messages:  1-10  11-30  31-50
