Display (mesh) problems
All  1-3  4-7
2095.4 In reply to 2095.2
Hi Michael....
May we know the progress of object organization ?
Btw, I am agree with you about you have to focus to improve moi instead of answer every question on this forum :)
2095.5 In reply to 2095.4
Hi Anis,
Well, rather slow so far I'm afraid. It's taken quite a bit of time to fix bugs in some other areas in the past few weeks.
I have finished some of the infrastructure of the properties panel piece, so that it responds to the selection changing and command UI coming and going properly.
It does not do a whole lot quite yet though, this is what it currently looks like right this moment:
Not very exciting quite yet... :) That is a new panel there that shows up when you are in selection mode, that is before you have started running a command.
The first things in it at the top will be an optional object name, and the object type displayed there, I haven't got it finished up yet but that type will say something like "Solid" or "Closed crv" so you can tell at a glance whether a selected curve or surface object is actually closed or not.
Then the idea is that there will be a few entries underneath this, probably one for color, and then a "Details" button and a "Tools" button.
The current idea is for the "Details" button to open up a big dialog box that has a bunch of more information about the selected object, that will probably be where stuff like the radius of a circle and length of a line will be listed and be editable. I was thinking previously about trying to build that information directly in to the properties panel, but there is not a whole lot of space to deal with there so I've been moving more towards an idea of having it on a dialog instead. That way it will make it much easier for me to provide quite a whole lot of stuff about the object. The idea for "Tools" will be to open up a drop-down menu with a bunch of more "advanced" tools that can be applied to the selected object type. It will probably end up as a sort of dumping ground for a whole bunch of things which will help to keep the top level UI cleaner for the more frequently used things.
I'll probably wait to release the new beta until I finish up at least some more of the basic stuff working on this properties panel.
The other major part for object organization will be the browser pane which will be a much larger panel that has a list of all the different objects and groups in it. I'm hoping to concentrate on that part not for this currently in-progress beta but the one after that.
2095.6 In reply to 2095.5
Teasing :)
2095.7 In reply to 2095.6
Keep on the right track Michael.... :)
Show messages: All  1-3  4-7
