Box modeling in MoI - Script request.
 1-4  5-24  25-28
2088.5 In reply to 2088.1
Hi PaQ, I see that the case that you want to speed up is more difficult because you want it to protrude from 2 faces instead of just a single face, is that correct?
You're probably doing fine with a single face, just offset, extrude, then union.
For the multiple faces I would probably go for these steps currently:
Select these edges - note the unselected one:
Offset:
Select these edges, again with the common one unselected:
Offset, use end snap to align the offsets:
Draw a line:
Select the line and the first offset:
And extrude (note, same as offset extrude does not need a join step, it will do it built in):
Select the line and the second offset curve and extrude - note there is no snap here to get precisely the same extrusion depth as the other one, but probably for your purposes if you just eyeball it to be close that would be ok?
Select the 3 solids and do boolean union:
No trimming or extending involved, so this is probably faster...
It would probably be pretty hard to come up with just a script to improve that, but it kind of calls out for some improvements to offset and extrude to handle a single outline that is made up of several different planar chunks. I'll think about that a bit.
2088.6 In reply to 2088.4
Hi Danny,
> Well it depends on the software, there are a few Cad programs out
> there where the extrude function has a few more features, like offset
> and boolean as you're extruding, for example: you could create a box
> using a single line.
Yeah, I would like to kind of incorporate some of that into MoI in the future, like some kind of operation for automatically fusing the result of an extrusion with a base object.
But typically in the CAD programs that do that, your extrusion is something that comes from a single planar sketch curve... Does NX handle the situation that PaQ is trying to do in this case of extruding from multiple different planar faces in one step?
Really the single plane case is not particularly time consuming in MoI either, you do have to use like 3 tools to do it, but it should come together quite quickly.
The multi-plane case takes a lot more steps though.
With the beginning of proliferation of scripts (actual and future) does not a cool idea
to make a visual dictionary ?
(same thing is arrived with ketchup actually more than 650 scripts! )
2088.8 In reply to 2088.7
Hi Pilou, definitely would be great to do that at some point.
Right now though there probably isn't enough time available to do that, I would have to stop answering questions here on the forum or eliminate some of the features of v2 in order to have enough time...
But at some point in the future that would definitely make sense!
And for your form I have a very more easy and speedy method!
Just remark that corner form is the same that the big primary form!
So just copy move it and Scale 3D !!!
And rescale it 1D for the irregular position for the "vertical" ;)
And make boolean Diff for the "Horizontal"
Seems to me very more efficient and speedy!
Scale method is very strong for simulate "box modeling" in nurbs when you have well understand the position of the "First Point"!
I have made the figure in 10 secondes ;)
EDITED: 16 Oct 2008 by PILOU
Size: 33.3 KB, Downloaded: 55 times, Dimensions: 357x376px
2088.10 In reply to 2088.9
It is in this particular example, but I don't think that will be the case in the situation that PaQ needs to use it in - there he'll have the primary form be some very large complex spaceship and these 2 faces will be just one small little part of it.
2088.11 In reply to 2088.10
Sure maybe a little more complex for the first post
but remark again right part is the same and the left part will work with your method! :)
2088.12 In reply to 2088.2
here the 2 faces of the internal angle selected
Faces selected are well inversed in edges selected but the Offset can't obtain result wished ;)
Same if I unselect the commun edge after apply script
2088.13 In reply to 2088.12
Hi Pilou, yes offset can not currently take all those curves at the same time.
If you follow the steps here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2088.5
You'll see that I select only one loop at a time instead of everything all at once.
You can select more than one curve to offset, but not when they touch like that, it tries to join those touching sections together into one loop and you've got multiple branches in there instead of one single loop result.
2088.14 In reply to 2088.6
No, it does't, same as MoI minus a few clicks. It will extrude multiple planar faces at once but at 45 degrees, then there will be a extra step in trimming the ends.
2088.15 In reply to 2088.14
So thanks for the 2 little scripts Michael, works perfectly.
I was more less using the same construction method, but with some uneened extra step (like joining lines before the offset).
2088.16 In reply to 2088.15
Hi PaQ - a bit of experimenting with a kind of "multi-planar" outline Extrude concept:
Still some things to clean up on it, but the idea is to make it recognize when a single closed curve is made up of multiple planar "chunks" and treat each of those chunks more like a planar face being shelled.
If I can iron out some of the details that could be one step to speed up this kind of box modeling process. There is some good possibility to add similar multi-planar single-outline processing to Offset and Planar I think.
2088.17 In reply to 2088.16
Michael, I just can't wait to have my hand on it !
Looks so simple and natural :)
Christmas for PaQ :)
But it is always Nurbs modeling? ;)
EDITED: 19 Oct 2008 by PILOU
2088.19 In reply to 2088.18
Very nice, Michael ...
It could be very useful for me, too.
eric
2088.20 In reply to 2088.19
The kind of corresponding thing for Planar would be to be able to make a shape like this:
Into a solid by adding 3 planes with just one go of the Planar command.
But I seem to have run into a pretty major snag though, with the problem of multiple possible planar groupings.
Like for example this shape:
You would want this planar grouping I think:
But here is an alternate planar grouping (same curve viewed from a different angle to see the different planes more clearly):
Maybe that one is solvable by using the smallest number of planes... But this one looks pretty hard to decide:
For Cap there would be a way to figure out which of the 2 was needed since the one that overlaps existing planes could be avoided. But for just a standalone curve being processed I'm not sure if there would be a good way to choose...
I'll have to think about it for a bit but I'm not so sure right now if this will really work as I had initially thought....
2088.21 In reply to 2088.20
So you must have one more line (or 2 clicks) for kill the incertitude :)
2088.22 In reply to 2088.21
Yes, it seems so... But adding 2 clicks creates a new problem of making the UI and workflow for Extrude more complex.
If I can find a way to make one of the existing commands more powerful without adding any additional UI complexity, that is something that I try to jump on and make a high priority. I thought I had one of those situations here but maybe not after all...
But yes maybe the full answer is that it needs more lines drawn in there to define all planar regions better. But then that starts to get away from the benefit of having fewer steps as well.
However, as part of this experiment, I also made an improvement to shell which is definitely nice. Previously when shelling a surface like this:
In the resulting solid you would get multiple pieces along the top, one for each original edge:
Now that is tuned up to combine those fragments that are all coplanar into a single plane:
That is something that was already happening with Boolean union, this is now added for the case of shelling a surface into a solid.
2088.23 In reply to 2088.19
Yeah, looks great Michael!
Steve
2088.24 In reply to 2088.22
Cool Michael, one thing leads to another, but watch out for that snowball effect :)
Show messages:  1-4  5-24  25-28
