About Extrude
All  1-2  3-5
2084.3 In reply to 2084.2
Is it more clear? :)
The first volume not created is parasite!
And the first point is not yet clicked!
Will be cool when Pushing the button "Set Dir" the parasite volume should be disapear like Set Path :)
(not vital but more comfortable and clean) It disapears at the First Point Clicked :)
Ps Thx for the "parent"
EDITED: 15 Oct 2008 by PILOU
2084.4 In reply to 2084.3
Hi Pilou, sorry about that I think I understand correctly now!
Yes - that would definitely be better to clear any previous temporary result when using "Set dir".
I have set this up for the next v2 beta and actually all the changes required are inside the Extrude.js script command, so if you would like you can update your current version with the attached Extrude.js command script to get that change.
Just copy this one over top of the old version inside of the \commands subfolder.
Does that then do what you were asking about?
2084.5 In reply to 2084.4
Perfect!
Woks like a charm and is very well adapted to the fonction! Now all is neat & clear! :)
Show messages: All  1-2  3-5
