Knurling
 1-8  9-28  29-32
2072.29 In reply to 2072.28
>Back a while ago some guys had an interesting project where they captured the polygon >output from a RenderMan renderer (I think maybe AIR?)
That's correct Michael. AIR engine can do this. Also Rhino can do this (not as advanced as AIR yet). And Modo as well. Both AIR and Rhino can displace Nurbs objects directly and output a displaced mesh...
@ Brian - The idea to use a screenshot as displacement map only works if you can grab an image of the screenbuffer (see attached image) looking from the Top viewport. This is great for making quick alphas from 3D models that you can apply to fake "hard modeling" details in your sculpting app, such as gears, wall sockets, etc... Or you can just make a single knurl feature and repeat it as many times as you need in U/V directions in your render engine. This is just simple pyramid made in Photoshop... A tiny bit of blurring may be necessary to get the best displacement effect...
jonah
Size: 19.6 KB, Downloaded: 37 times, Dimensions: 256x256px
Size: 96 KB, Downloaded: 68 times, Dimensions: 995x667px
2072.30 In reply to 2072.29
Hi jonah, one of the interesting parts about the AIR mechanism is that it allows for execution of renderman-style shader script programs.
That allows for writing completely custom shaders that actually execute a kind of script code to control the output. It's pretty much the ultimate in flexibility, but of course you have to write code to control it.
2072.31 In reply to 2072.29
jonah
Thats what I used of the MoI screen shot idea--and the top view.
Hey!, it worked ok for me! (Gosh, I use colour image files regularly for displacement also--no probs!)
I am thinking more now of just going down the Carrara potentials I showed--not using any image at all. Seems far easier, totally simple and low file size. Why not?
Brian
2072.32 In reply to 2072.28
>My current thinking is that I may write a very simple and quick renderer that will be built in to do very basic stuff, but rely more on >plug-ins / 3rd party type renderers for more advanced type things.
That makes a lot of sense to me as well Michael. I've always liked that idea for some reason.
For example, there is an easy sketchup to kerkythea plug in, and Cycas has an inbuilt portal to povray. Though the two systems are a little different.
In both systems, it is possible to set up cameras, lights, materials inside the modeling program. In the first system, the scene is opened in KT and the rendering operation is controlled from there.
In the Cycas system you don't have to talk to povray at all. A very workable range of render settings can be selected from within the modeler. Which may be very good for some users who don't have time to get into the deep subleties of rendering.
Just some thoughts.
Show messages:  1-8  9-28  29-32
