Requests &...from Pilou:)
 1-6  7-26  27-46  47-66  67-80
3 Different colors for the basic "background curves" depending of the 3 axes?
like in this crazzy nurbs car's tut
http://www.etereaestudios.com/docs_html/nixus_htm/nixus_makingof_mp01.htm
(you can clic on the little up white triangle for more images :)
He uses directly curves and surfaces as "3D sketch" for research design !
another crazzy nurbs car tut by the same guy
http://www.etereaestudios.com/training_img/sentinel_tutorial/sentinel_tutorial.htm
Ps Little question
How use the "Circle tangent tool" for have a circle tangent between the "big rectangle" and the "big circle" and touching 2 precise points?
(the center of the little circles) ?
(because when a point is yet drawing on a curve, this point can'be choosed as first point of a curve of the tangent tool :)
If exist of course, seems not in this case of the little circles, but in the general way?
Like the 2 points (center of the little rectangles)
This last one exist
( I have drawing the circle tangent first and draw the little rectangle by centers after (curve "on" + intersection) , erased the circle :)
Or I must read a geometry's manual for construction of particular figures :)
EDITED: 27 Nov 2006 by PILOU
207.48 In reply to 207.47
Hi Pilou!
Eventually this will be possible when there is stuff added to change object properties.
Re: Tangent
The circle tangent tool does something a little different - it gives a circle tangent to two curves, of the specified circle radius, it then calculates the points for you. This is different than using specified points.
To use specified points, you can use the regular Circle/Center and construction lines.
For a circle to be tangent to a curve at a point, it means that the center of the circle must be on the perpendicular from that point.
So to draw such a circle, start the Circle/Center tool, then drag out a construction line perpendicular from the first point, and drag another one perpendicular from the second point, and then the center will be where they intersect, but the solution is only possible if the intersection is of equal distance from each point.
But that is a lot of constraints, so if you just pick any 2 points I think that most of the time you won't find that there is a solution.
207.49 In reply to 207.48
It's the definition of the center of a circle :)
Your tangent tool circle is like a rolling ball bearing :)
I suppose that is its use :)
Many circles are possible in my funny example without 2 specifics points
(circle tangent between big curves restangle/circle)
Geometry is always amazing :)
Thx for te explanations & precisions
207.50
Michael,
Will constructions lines be able to "stick" in the next version?
207.51 In reply to 207.50
No, I probably won't be able to do this for a while. I would like to eventually make it possible for them to stick around after the current command by hitting some option, but there are a few complications that go along with that.
Probably they should stay more in the background and not interfere with selecting other objects, but on the other hand there also has to be some way to select them so you can delete them at some point.
If you do need a more permanent line that will last through more than one command, right now you have to just draw a regular line for that...
207.52 In reply to 207.51
< right now you have to just draw a regular line for that
And this line will be skip when you export your model because it was not a surface
And carreful even a triangle of 3 lines will not "export" too if you have not make a "plan" between them :)
Different than a normal save in 3dm where lines will be saved even they are not made a surface :)
207.53 In reply to 207.52
Also IGES - curves are only written to 3DM or IGES files.
A fully screen without UI?
Practical for a maximum "snapshot image" and total immersion :)
207.55 In reply to 207.54
It's not perfect, but this will get you mostly there.
First, create a new "scripts" directory underneath the main MoI program directory (on an equal level as "commands" and "ui").
Unzip the attached FullScreen.js and put it in there. So the path for this file should be something like: C:\Program Files\MoI beta Dec-1-2006\scripts\FullScreen.js
Go to your moi.ini and add a line:
[Shortcut Keys]
F11=FullScreen.js
Now pushing F11 will toggle the UI on or off. Right now there will be a little blank area left, I think I should be able to remove that for the next beta. (edit: yes, this is now fixed for the next beta so there won't be any extra blank space).
EDIT: updated attached script to work with new UI panels added in v2.
EDITED: 1 May 2010 by MICHAEL GIBSON
207.56 In reply to 207.55
Thx :)
Try that in a short while
Full screen works like a charm !
There is yet of course the little vertical white line, but very little if you put"0" inside the Size of the UI in the Options :)
About the "ini" file : how this file is managed when a new beta is released?
Adding, crushing, overwriting?
Automatic or we must copy/past some lines of the the previous file?
207.59 In reply to 207.58
The new beta will use the same file .ini file as the old beta. The .ini file will get things added to it if there are any new settings in the new beta, but all the old stuff will stay as it is. So that part is automatic.
But you will need to copy the FullScreen.js file again for the new beta though, that is separate from the .ini file.
Sorry no time now for think of that, but I suppose it's a classic construction :)
How draw the red curve "Developping of circle" with moi ?
207.61 In reply to 207.60
> No time for think of that, but I suppose it's a classic construction :)
Hi Pilou - many of these types of mathematical curves are not really suited for "drawing" with the mouse exactly. This is the type of thing that you would probably need to generate using a more specialized program, maybe something like Mathematica.
It would be possible to construct this in MoI by using some fairly complex scripts to generate a point list and create a curve using those points. But that will be pretty involved.
207.62 In reply to 207.61
So I must think more about this little problem :D
Graphic construction must be possible with only clipers(?) and ruler and "Through point line" :)
What is the exact name of the curves that is used in Moi :"Through point?"
Nurbs yes but what about the tangent ? or the degre of tension (streching) between 1 point between 2 points?
EDITED: 21 Dec 2006 by PILOU
Something cool that I have not yet seen ! :)
Circle "tangent" can be draw along the "helpers lines"
Take the Circle "tangent" function
Draw somes "helpers lines"
Clic 2 points on these helpers lines
The possible circles are drawing moving !
Ps Request : "Helpers lines" can be also " Helpers circles"
Seems that will be great :)
Rules and dividers are the bases of geometry :)
207.64 In reply to 207.62
The method for creating that type of curve is usually called an "interpolated curve". One good reference for this is The NURBS Book, Les Piegl & Wayne Tiller, Springer-Verlag 1995–1997.
You may be able to find something online about "NURBS interpolation".
The version MoI uses creates a tangent automatically. You can edit it later by turning on control points and moving the second-to-last point around.
The tension is actually updated for the next beta release, it will use a type called "centripetal knot spacing".
But the "Through point" method is not really the best way to create a curve for the method that you are thinking, though - because it forces the curve to go exactly through every point, it tends to create wiggles in the curve when you have many points. For creating a curve through many points there is a different process called "fitting" which creates a curve that is guided by the points (to a certain tolerance) but is not forced to go exactly through them. That is usually a better way to get a smooth curve. MoI doesn't expose a way to do this right now, but Rhino does with the FitCrv command.
207.65 In reply to 207.63
Hmmm. But it's not too hard to just draw a circle to use for such a construction, and delete it after you are done...
A line is kind of a special case since a construction line extends infinitely in each direction so it gives something extra (beyond the automatic cleanup) than just drawing a regular line.
A "construction circle" wouldn't really give very much extra benefit over just drawing a regular circle.
207.66 In reply to 207.65
Just for the beauty of the thing :)
So for the permanent figures
a nature of the draw (solid, dashed, dotted...)?(as the grid lines)
Show messages:  1-6  7-26  27-46  47-66  67-80
