Requests &...from Pilou:)
 1-6  7-26  27-46  47-66  67-80
207.27 In reply to 207.25
Hi Petr,
> Is this bug, feature or my mistake?
I consider it to be a feature. :)
This particular thing tends to be an area of confusion in Rhino, that typing 5,5 produces a different 3D point location depending on what viewport is active. It is particularly bad in the split view where it is so easy to accidentally change the active viewport just by moving your mouse around without even clicking somewhere.
In MoI this is different - simple coordinate input with no decorations (like 5,5) will always use world coordinates. I think this is really what most people would expect (unless you have become accustomed to other software that does it differently of course).
That just helps to eliminate one area of confusion. The "w" syntax is supported to do the same thing just for people who are accustomed to it from Rhino.
There is currently no way to type in construction-plane relative coordinates. I suppose I could add this in using a new "c" syntax, like "c5,5". What do you think about that? There is not exactly the same concept of an "active viewport" in MoI as there is in Rhino though. But internally there is a concept of the last clicked viewport, and there is also the concept of a full-screen viewport. So the way I would figure it would work is if you have a full screen viewport, it would use that viewport's construction plane, otherwise for the split view it would use the last viewport that was clicked in.
207.28 In reply to 207.26
So reserve 'auto intersect' for exotic topologic forms like Boy's Surface or Klein' s Bottle or Big Bang / Big Crunch and Black's Hole :)
207.29 In reply to 207.27
...not to be confusing for me. When I work in 2D view I am just drawing and don't care about 3D.
yes, I must agree with you in that, it sometimes happens to me, haha...
>> ...simple coordinate input with no decorations (like 5,5) will always use world coordinates. I think this is really what most people would expect...
It is hard not only for me to place a points in 3D space while looking at "non-corresponding" 2D view, so I might value something like "c5,5" or it seems to be better idea to add world axis icon to non-3D viewport, so I wouldn't be confused enough. On the other hand, MoI's construction lines is so powerful (it just groups Rhino's ortho mode, elevator mode, planar mode, tab constraint and AshlarVellum's DraftAssistant together) that users are encouraged to work more in the 3D view where "w5,5" or "5,5" is the same. Besides, it can always be done with drawing in Top viewport and then rotating the drawing.
I think that the rhino's concept world coordinate system 'wx,y,z' versus local one is essential because there is a way how to change the direction and origin of the construction plane. For instance, if I change the origin in Rhino's Perspective view and type "5,5,5" vs. "w5,5,5" there will be absolutely different location of the points. Thus, if you decided not to add the command handling a construction plane, you could give up new 'c' idea perhaps
By the way, it makes no sense to initiate an input field after typing "w" or "r" without running command, so this is a misfeature I guess
Petr
207.30 In reply to 207.29
Cool, I'm glad that you're finding it useful! I think the other important factor is that it stays out of your way until you call for it with the drag gesture. I've seen many other systems that get triggered too easily and then sometimes end up getting in the way.
I'm not planning on adding construction plane handling in for V1, but I haven't given up on it forever. I think it will come in future versions.
Once you have set a custom construction plane, I figure it will probably affect all views and then at that point it would probably make sense for typed-in coordinates to be in that new coordinate system instead of world. I don't think that would be surprising anymore, because you would have to do something in particular to activate it.
But just having the coordinate system shift by having a particular view active is more of a problem.
I've fixed this for the next beta so that focus will only go to the xyz coordinate input if there is a point currently being picked.
Does exist a "full screen" without the UI? (just keeping Zoom Pan Rotate...)
Ps What is the utility when you make a loft of the "Clic on curve for change seam"?
Ok that permit to "move" the seam, works fine but what is the use of that :)
EDITED: 19 Nov 2006 by PILOU
207.32 In reply to 207.31
No not right now. I've thought a little bit about making some way to collapse/expand the side pane and bottom toolbar to make this possible, but I don't think that this will be available for V1.
Most of the time there isn't any use in it because the automatic calculation for how to align things works pretty well. But that method is provided in case the automatic alignment didn't work very well.
Filet in this case is pemited?
Edit Very curious I have reload the file and all was Ok!!!
So Does exist a "refresh" function? (reinialize of Pan Rotate don't refresh that)
ps What is exactly history?
Can make this?
Object filet, modif, modif....
Replace at the end the first filet by a chamfer
EDITED: 20 Nov 2006 by PILOU
207.34 In reply to 207.33
Hi Pilou, this is a bug in the display. The object itself is fine (all the surfaces and trim curves, etc..), and when you reload it, the thing that triggers the bug will be gone and so it will work then. This display bug is fixed for the next beta.
History is a mechanism that saves the parameters that you used to create an object. But right now the only parameters that you can change are the input objects. For instance if you do an extrude from a curve, if you change the curve the extrude will update.
> Can make this?
Not yet, because of a couple of reasons. First, it is not changing an input object, it would be changing different parameters such as a radius or the type of operation. Eventually there will be some kind of UI mechanism that allows you to see and modify these types of values, but that is going to be quite complicated to finish so it won't be ready anytime soon.
The other thing is that when you do a fillet, the original object (before the fillet) is deleted. The history mechanism needs to be able to find the original object in order to apply changed parameters to it. I have some ideas on how to make this possible, but again it is fairly difficult so it will be a while.
There is a different style of CAD software called a "Feature-based parametric solid modeler" which is very much designed to operate like you're asking for. Some examples of this are SolidWorks, Alibre, Inventor, Pro/E, etc... MoI is not really set up to do exactly the same thing as these.
207.35 In reply to 207.34
Thx!
All is clear :)
What about the "cracks" in general?
Is just an visual effect due the screen definition & zoom
or model of Breps(Boundary Representation) volumes result are always "watertighness" in Moi?
Is there an option for regulate that ?
Whish list :)
A "plan work-grid (or -view)" aligned by 3points (or by view) ?
207.37 In reply to 207.36
Cracks like you show there are usually a visual effect due to slightly different mesh structures being created.
It looks like you have two separate surfaces there - if you join them together into one single brep that has a shared edge, you shouldn't see a crack there anymore. That's because MoI will create the same mesh structure along shared edges.
Breps that have no "naked" edges are watertight - that is when every edge of every surface is joined to some other edge.
This makes it topologically "watertight".
If you have just individual surfaces that are positioned next to each other but not joined, that is not watertight because none of the algorithms in MoI have any knowledge that the surfaces are really supposed to be connected to each other.
> Whish list :)
In the future at some point I want to add some functionality like this for changing the working plane (which I call the "Construction plane"). But I don't think that this will be available for the initial V1 release though.
207.38 In reply to 207.37
Thx
Another little question :)
What is the normal use of a volume made in a Polygonal Prog ---> transform in Nurbs --> import in MoI
(so some Nurbs surfaces :)
Select all / Separate / Select all / Boolean Union ?
(file 3dm linked: volume on the left is the "poly" transformed in Nurbs) on the right the operations line above )
Seems all vertical facetts don't weld in only one facett?
Ps Does exist in Moi an automatic function after an auto-trimming of several nurbs surfaces for delete all that not define a volume?
Coons and Gordon surfaces are implicit inside MoI or don't exist?
coons planes http://www.cs.technion.ac.il/~cs234325/Applets/applets/coons/html/index.html
Gordon surface generated by latitude curves and longitudes curves with for each one point commun with each other :)
EDITED: 23 Nov 2006 by PILOU
207.39 In reply to 207.38
The object on the right appears to have a lot of duplicated surfaces in it, I think that is causing the problem there.
One other tip - although boolean union will often work for this, it is really not quite designed for this type of operation, it is more intended for objects that intersect each other (by pushing through each other, not just along edges only). If you have a bunch of surfaces that just touch each other edge-to-edge, then you'll get better results from using Edit/Join to bring them together, it is designed for that type of situation.
No this does not exist in MoI currently. It would be possible to add this function, but I'm not very sure that it is really that useful, since it only functions in this particular case where you have created several surfaces that are extended past each other on all sides. You can get the same results right now by just doing regular trim followed with a join.
Maybe at some point in the future I can add this in as a special case for one of the boolean operations.
They don't exist right now, but I do plan on adding these.
207.40 In reply to 207.39
Thx
Something curious
Curve / Revolution / Shell / Booelan Diff with a Sphere
Why the shell resulting is "open" on the Diff internal facetts ?
207.41 In reply to 207.40
Hi Pilou, it looks like the shell is not a complete solid, there is a tiny open edge on the bottom:
But the strange part is that it doesn't seem to be in the original revolve, it seems to have happened after the initial shell?
There seem to be a couple of problems with shelling revolved shapes right at these pole areas.
207.42 In reply to 207.41
Remake some try, and that seems rework fine :)
3D nurbs are full of mysteries !)
Seems solution is to remake all the shell to the wished result :)
Or what happen when you clic both on the generator curve and
surface to shell?
generator will be skiped?
207.43 In reply to 207.42
> surface to shell?
Yeah, shell only works on surface-type objects, it just ignores any selected curves.
One thing to be careful of when you do the revolve is to make sure that your revolve axis is snapped right on to the end of the curve. It seemed like it was ok there though.
207.44 In reply to 207.43
Say in Font view ; a sinusoid curve vertical
For revolve I take any other vertical axe without any snap on the curve and the revolve seems oK? ;)
207.45 In reply to 207.44
Yes, I'm sorry I wasn't clear - it is not required that you can only have the revolve axis at the end of the curve.
But if you do want to place it nearby the end of a curve, then you should make sure that you snap it directly on in that case, because you can create a bad surface if the generator curve is sticking out a little bit past the axis, like this:
And if it is very close by but just a little bit on the other side, then there can easily be a hole there that you might not see very easily since it could be very small.
207.46 In reply to 207.45
Undestood :)
Yes and in this case there is even an "auto revolution" :)
So effectivly maybe some problems :)
Show messages:  1-6  7-26  27-46  47-66  67-80
