What did I do wrong THIS time?
All  1-7  8-12
2061.8 In reply to 2061.7
> These are the default settings ?
Yup, except for tangent snapping turned off, but that should not have anything to do with this.
> Are they not as they should be?(Sorry for the trouble)
Yup, that part does not seem to be the problem.
Can you describe in a bit more detail how you are drawing the curve again? I cannot repeat the problem over here when drawing in the side view. If you pick any points in the 3D view stuff like that could happen but when that setting is turned on, points picked in the 2D views are supposed to generate 2D flat curves.
2061.9 In reply to 2061.8
Michael.
Starting from scratch.
Insert a sphere
Go to Right View
Draw a Control Points line
Attempt a Trim--not working?
Brian
EDITED: 31 Dec 2008 by BWTR
2061.10 In reply to 2061.9
Hi Brian, I don't really know how you're getting it but one section of your points are on on the world plane where I would expect, and then the second half of your points are on a different depth.
What happens if you turn off all the snaps - that is click on "Grid Snap", "Straight Snap", and "Object Snap" in the bottom toolbar so they are not highlighted in orange anymore. Does that make any difference for you?
I am not able to reproduce your problem over here - I've attached what happens here when I use a control point curve clicking every point for it in the right-side view.
Are you possibly getting some construction lines kicking in? I mean do you see any long dashed lines popping up while you are drawing the curve?
Any other possible details that you can think of, like do you tend to use undo while drawing the curve a bunch, adjust your view, any stuff like that?
2061.11 In reply to 2061.10
I think I know what is happening, you're tracking along a surface normal line for one of the points.
If you look closely, you will probably see a long dashed line with a label that says "normal" on it - that is the tracking line that is messing up your curve.
Probably the easiest way for you to get rid of that at the moment is to disable Straight Snap on the bottom toolbar (click it so it is not orange). That will eliminate that tracking line which I can see can pretty easily disturb drawing in that 2D viewport.
I probably should disable that surface-normal line when drawing in a 2D viewport. I've been actually thinking of disabling all the stuff related to the new-for-v2 "on surface" object snap in those 2D views because they can tend to get in the way of simple 2D drawing.
I will try to get these tuned up for the next beta so that they won't cause this problem anymore, but for the moment turning off Straight Snap should do it.
2061.12 In reply to 2061.11
Michael
I hope this makes sense and is helpful.
With Straght Snap ON
Get 3 things as drawing a line; variations--- tag "On Srf"; and/orTag "Normal, and/or construction lines
Special note. However, if I draw a series of lines separately, one after another, there are variations between each. Some are "twisted", some are "flat".
With Straight Snap OFF.
Consistently only the "On Srf" tag. Flat.
Doing repeat lines still all flat.
Think that clarifies that a gremlin is involved I think?
Thanks for the temporary solution.
Brian
Show messages: All  1-7  8-12
