igs and stp import export
 1-11  12-28
2047.12 In reply to 2047.11
Hi Steve,
> Michael G, I could not get Alibre to see that test_circle.stp file
> at all. I tried various import options but nothing showed up
> on the display.
That one was a circle curve, when you mentioned circles previously I was thinking you were talking about a circle curve like you would draw with the Draw curve / Circles / Center command in MoI.
But from your example it looks like you are more interested in circles that are edges of solids.
For reading the curve into Alibre, I'm not sure how that works exactly, but you may need to do some command like "import sketch" or something like that to read curve data in (rather than solids).
Just one other test to make sure I understand what is happening, do you also get the same problem with the additional cylinder_test.stp attached here?
And can you create a minimal cylinder object like that (with nothing else) in Alibre and post that here for me to compare with?
I think that the STEP library that I am using does not have this function in it to write out circle entities instead of spline entities, so there may not be anything that I can do about that immediately. But I have sent an e-mail to the author of the step library to ask if he can include that function in the future.
2047.13 In reply to 2047.12
Hi Steve and Michael G.
Here is a PDF file from Alibre's design guide regarding import and export for Alibre Design 10.
Hope it helps. You can download Alibre's complete user guides from the web site.
I don't want to clutter up Michael G.s forum :-)
Michael T.
Michael Tuttle a.k.a. mictu http://www.coroflot.com/fish317537
EDITED: 4 Nov 2010 by MICTU_UTCIM
2047.14 In reply to 2047.13
Hi All....
Below are the test result :
Size: 21.7 KB, Downloaded: 90 times, Dimensions: 628x471px
Size: 29.5 KB, Downloaded: 67 times, Dimensions: 733x559px
2047.15 In reply to 2047.13
Hi Michael T, thanks for posting that - unfortunately it doesn't seem to cover technical details like what kinds of entities are recognized as circles...
When you import into Alibre, there are a variety of import options including things like "Heal solid", you might try enabling those options to see if that will make Alibre recognize the circles or not.
2047.16 In reply to 2047.15
Hi All
Michael still no go with your cylinder_test file.
Just to clarify, my interest here is in being able to take a model from MoI into Alibre and use the "create drawing" feature with dimensioning, annotation, etc.
Anis' result is the same as mine. In Alibre's drawing window, the dimensioning utility should recognise the circle and dimension it as it does in SoidWorks. But it doesn't happen. It is the same in the 3d window of Alibre...one should be able to dimension circles there too. Lines are no problem .
I tried quite a few import options without success.
Here is a cylinder object made in Alibre. There are options to export 3 diff types of stp file, I just picked one.
In MoI when one makes a cylinder by extrusion, it is customary to delete the original circle, whereas in Alibre the original circle remains as an editable object. So I also tried extruding a cylinder in MoI and not deleting the circle. But Alibre would have none of that and refused to even open the file.
I will keep playing around as and when I have time. But, Michael, please don't loose sleep over it!!
2047.17 In reply to 2047.16
Hi Steve, I've talked to the author of the STEP library that I'm using and he says that it should not be very difficult to enable an option to write out circles as "circle" entities instead of as more generic "spline" entities. I'm not exactly sure when that will be complete but it is somewhere in the queue now.
However, he also mentioned that there is an option for this that can be enabled currently for IGES export.
I've attached a test file that sets that option.
Can you please see if this cylinder_test.igs file works better for dimensioning in Alibre?
If so then that is one thing that will be easy for me to set up for the next v2 beta, and that could be an option to get it done until the STEP equivalent is ready.
> open the file.
That seems to be a particular quirk of Alibre - other programs seem to deal with curves present in a STEP file as well as solids... If they don't want to read in "stand alone" type curve data, they should just skip them instead of failing the whole import. I think that one is something that they will need to fix up in Alibre.
2047.18 In reply to 2047.17
OK great news, Michael
With your igs test file it is possible to dimension circles in 2d drawing mode.
Also, in 3d mode, Alibre recognizes the cylinder edge as a circle.
So that seems like the solution. I don't think it really matters to many people whether they export from MoI as stp or igs.
EDITED: 14 Oct 2008 by STEEVE
Size: 26.8 KB, Downloaded: 35 times, Dimensions: 711x513px
2047.19 In reply to 2047.18
Hi Steve, that is great news!
So for the next beta the IGES export will be tuned up to do this by default - it will export lines, circles, and arcs as those specific kinds of entities in the IGES file instead of as generic splines.
If it causes any problems (not likely but just in case), it will be possible to turn that off and return to the old behavior by editing an entry in the moi.ini file:
[NURBS Export]
WriteAnalytics=y
Later on at some point this will happen for STEP as well.
2047.20 In reply to 2047.19
Thanks again Michael, that will certainly be a valuable feature!
2047.21 In reply to 2047.20
Very cool Michael G.!
Good luck Steve!
Michael T.
2047.22 In reply to 2047.21
OK here's a funny thing.
Even with the current igs export set up in MoI (V1.0 and V2.0 beta) Alibre can recognize circles!
So I guess nothing really needs to be done:)
Steve
2047.23 In reply to 2047.22
Hi Steve, well that's interesting! I wonder why they detect circles only for IGES and not for STEP format...
So anyway, that's great, you can get your stuff working right now even before the next beta is out.
I think I will leave the new "simple entity" stuff enabled anyway though, maybe it will help some other programs to recognize them.
2047.24
is this problem of detecting circle in Alibre of imported STEP file resolve yet?
I have several solid models in MOI which i want to constraint it in ALibre. already export is as STEP so that alibre can import it as assembly of several parts.
if i have to export it as IGS in MOI, then i have to export the solids one by one and import it again one by one in Alibre.
2047.25 In reply to 2047.24
Hi Bud,
I'm not really 100% sure - but this discussion thread is 4 years old and I don't think that it has been mentioned as a problem for quite a while now. So it's possible that it has been tuned up in the Alibre STEP importer since then.
I don't know for certain though, I'd recommend testing it yourself with one of your specific models to make sure it does what you need.
If it does not work correctly, try going in MoI to Options > General and push the "Edit .ini file" button and go to the [NURBS Export] section and set:
[NURBS Export]
WriteAnalyticCurves=y
WriteAnalyticSurfaces=y
It kind of looks like the circle case for analytic curves is still not handled in the import/export library, but it does seem to be active for surfaces, with a cylinder then getting written out as a specific cylinder surface entity in the generated STEP file and not as a generic NURBS surface. That could possibly help if Alibre is not recognizing the surfaces as cylinders automatically itself.
There is a post on the Alibre forum about this. http://forum.alibre.com/viewtopic.php?f=10&t=14941
2047.27 In reply to 2047.26
Thanks Brian - so it sounds like enabling the "heal" option at import time in Alibre will make it recognize circles.
2047.28
thanks for the feedback Micheal. actually it was me who posted in Alibre forum. so it resolved now :)
Show messages:  1-11  12-28
