BUG report - Fillet broken after a mirror + undo
All  1  2-6
Idem! Also bug at home ;)
@PaQ your screen captures are some large! :)
Have you a 40 inches?
2044.3
Nope only a 34 inch :P
(will make smaller captures next time ;))
2044.4 In reply to 2044.1
Hi PaQ, thanks for the very clear bug report!
I have been able to repeat the problem over here and I've been looking at it.
It appears that the object actually gets messed up directly after the mirroring, it is just that the mirroring also copies the display mesh of the original object so you don't notice the problem until later on at some point when it gets re-meshed which is what happens on an undo.
It also does not seem to happen with V1, so it looks like it is a regression in the geometry library involving dropping curves to parameter space.
I'll be taking a look to see if I can narrow it down to a specific area and see if I can possibly roll that part back to the v1 state.
2044.5 In reply to 2044.4
and strange that it wasn't reported before too. G1 fillets doesn't have this problem.
EDITED: 6 Oct 2008 by PAQ
2044.6 In reply to 2044.5
Hi PaQ - this fillet + mirror bug turned out to be a bug in handling mirrored spheres, for the part of bringing points from 3D space into UV parameter space.
It's fixed up now for the next beta, thanks very much for the clear bug report!
Show messages: All  1  2-6
