Modeling Help for this....
 1-2  3-22  23-42  43-54
2042.3
hi use sphere trim and blend
2042.4
Hi lyes, thanks for sharing this blending technic ! I would never think to use this fonction that way :)
EDITED: 4 Oct 2008 by PAQ
There are always many tricky technics! :)
< hi use sphere trim and blend...
...and box of deformation ;)
2042.6 In reply to 2042.5
Still have a little question about the trim,
Is it 'normal' that when I try to trim A by B
I finish with an extra segment ?
(which is annoying for the blending :/)
EDITED: 3 Dec 2015 by PAQ
2042.7 In reply to 2042.1
Hi slayer.
A different approach with 'Network'
EDITED: 24 Oct 2008 by PAOLOLOBBIA
2042.8 In reply to 2042.6
@ Pac
If I copy move the curve + the the line then trim outside the object all is fine :)
I believe there are several things selected when you click for select the curve!
And then the trim seems fail :)
2042.9 In reply to 2042.8
Sure triming the extacted curve works, the problem is that I need/want to trim the surface edge ...
And it's not like the trim failed, but it will add automatically a segment that I don't really need.
2042.10 In reply to 2042.9
Just having a quick bit of fun. (Could not sleep!)
No problems doing it at all
Brian
EDITED: 31 Dec 2008 by BWTR
2042.11
Thanks for all the replies. I was able to achieve a basic shape from the method that Lyes showed. However, I am curious how to get the results with blend that Lyes is showing....
2042.12 In reply to 2042.11
Quite mad!
Brian
2042.13 In reply to 2042.6
Hi PaQ,
I have tried it to to trim A by B and
like you explained and,
it gave me the same problem
So it must be a 'bug'
2042.14 In reply to 2042.6
Hi PaQ,
Currently it is - every closed curve, including trim curves has a "seam" point where the start of the curve touches the end of the curve.
It is not unusual for chunks of the NURBS library code to treat a closed curve or edge the same as an open one when it gets diced into pieces. That usually means that there will be a couple of extra small segments created, one from the "start" of the closed curve to the first cutting point, and then another one from the last cutting point to the "end" of the closed curve.
I've tried to clean this up in several places already, like when you trim a circle curve you don't get an extra point at the seam because of some extra work that I did to fix that case up.
I do expect to be able to improve the surface edge case as well, that is actually bumped up pretty high on the todo list. It can also help fillets to avoid diced up edges as well.
2042.15 In reply to 2042.14
Nice work guys, very cool design.
Cold
| Adobe Photoshop CS | Corel CorelDraw Grahics Suite X3 | Daz 3D Bryce 5.5, Carrara 6 Pro, Hexagon 2.5 | Maxon Cinema 4D R8.2 | Moi 3D |
Gallery
2042.16 In reply to 2042.15
LOL, Brian, you're going all Captain Nemo on us! :-D
-Will
2042.17
hi slayer use blend G1 2.5 , here is my resulte and is not finish yet
2042.18
here is video how to blend audio on
http://www.screencast.com/t/x2q2eOMPEHN
EDITED: 6 Oct 2008 by MICHAEL GIBSON
2042.19 In reply to 2042.17
Hi Lyes,
Oh that is so nice, very nice.
Can't wait to see the finish one.
Cold
Gallery
Cool teasing! :)
2042.21 In reply to 2042.18
Hi lyes, I've tuned up the forum so that pasting in the "share" HTML into a message will let you embed a flash video into a forum message properly now.
Before it was screening out some of the stuff that was needed.
2042.22 In reply to 2042.21
Michael,
Where's the share function for embedding?
Show messages:  1-2  3-22  23-42  43-54
