why can't I get smooth bottom?
All  1-3  4-5
2032.4
Thank you PaQ and Michael for your replies
I have tried the way PaQ adviced and it did work!!! Many thanks
PaQ, I meant the part where the smalest circle is located.
There it was not perfectly smooth. Now it is.
I wonder if I pick RS and the opposing curve for rails and 1 or 2 for scaling rail it turns out differently in this area next to the smallest circle.
Could you please tell me why?
Olga
2032.5 In reply to 2032.4
Hi Olga,
Doing it in that order creates a "steeper" type dropoff for the scaling rail, it is similar to the kind of "cliff" type profile as described here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1807.7
The scaling rail will not tend to work as smoothly when it has a larger zone of it which approaches the centerline at a steep angle.
The link above has some illustrations that try to explain this some more.
Basically when there is a very steep angle for the scaling rail it makes the sweep go through large distance changes for every small distance traveled in the sweep direction, that will tend to not create as good of results.
Show messages: All  1-3  4-5
