MoIinWood
 1-16  17-36  37-56  57-62
2022.57 In reply to 2022.56
The entire thing costs around 6-700$ to make. Without labor. If you count that with a reasonable rate you would have to allocate around $1600. Motor is a 90-0Oz/Inch $100 one from Ebay/Hongkong/China in this case and the electronics are from geckodrives.com. I use EMC on Linux with a realtime kernel. MS-Windows and Mach3 would work as well but has the usual MS dependent 'features' which means that it will work and that there is a reasonable explanation every time it fails. Other parts I either had or ordered from McMasters which happens to be almost around the corner.
Lemo
PS: You also need a Small Machine Shop to make it... Mill, Lathe, Bandsaw...etc... etc... all that good stuff which brings one close to a divorce....
2022.58 In reply to 2022.57
Good source for motors: http://www.kelinginc.net/
2022.59
Here is a carving I made with my machine. The pre viz is in the gallery.
I'll be giving some classes/workshops soon in the Bloomfield, NJ area which is 20mins and two train stops away from Penn Station in Manhattan.
From idea to solid model, all hands on. Not a plain lecture.
If there is interest within the MoI community , please let me know as there is a discount.
Rainer
2022.60 In reply to 2022.59
It turned out great Rainer! That's also cool idea to do a sort of "start to finish" workshop.
2022.61 In reply to 2022.59
hey, thats really a nice thing. what machine are you talking about?
cheers,
ello
2022.62 In reply to 2022.61
The one I build 8). 4x8x28 inches envelope, servo driven 5 axis.
Rainer
Show messages:  1-16  17-36  37-56  57-62
