MoIinWood
 1-15  16-35  36-55  56-62
2022.56 In reply to 2022.18
Could you please comment more on where you obtained the drive motors and electronics? Also, as always, pricing? Are you using Mach control software?
2022.57 In reply to 2022.56
The entire thing costs around 6-700$ to make. Without labor. If you count that with a reasonable rate you would have to allocate around $1600. Motor is a 90-0Oz/Inch $100 one from Ebay/Hongkong/China in this case and the electronics are from geckodrives.com. I use EMC on Linux with a realtime kernel. MS-Windows and Mach3 would work as well but has the usual MS dependent 'features' which means that it will work and that there is a reasonable explanation every time it fails. Other parts I either had or ordered from McMasters which happens to be almost around the corner.
Lemo
PS: You also need a Small Machine Shop to make it... Mill, Lathe, Bandsaw...etc... etc... all that good stuff which brings one close to a divorce....
2022.58 In reply to 2022.57
Good source for motors: http://www.kelinginc.net/
2022.59
Here is a carving I made with my machine. The pre viz is in the gallery.
I'll be giving some classes/workshops soon in the Bloomfield, NJ area which is 20mins and two train stops away from Penn Station in Manhattan.
From idea to solid model, all hands on. Not a plain lecture.
If there is interest within the MoI community , please let me know as there is a discount.
Rainer
2022.60 In reply to 2022.59
It turned out great Rainer! That's also cool idea to do a sort of "start to finish" workshop.
2022.61 In reply to 2022.59
hey, thats really a nice thing. what machine are you talking about?
cheers,
ello
2022.62 In reply to 2022.61
The one I build 8). 4x8x28 inches envelope, servo driven 5 axis.
Rainer
Show messages:  1-15  16-35  36-55  56-62
