I need some help please.
 1-5  6-25  26-27
2021.6
Hi there,
wow you are fast!
thanks alot for your quick answers.
you helped me alot.
@BurrMan: I've try'd your way first, but thats not exactly what i wanted. but thanks alot anyway!
@lyes: I'm gonna use your method, i have to put in some mor cp's and change the shape a bit to achieve my wanted look,
but thats ok.
this is what i've got so far:
like i said, the second method is better but i have to tweak/put in some points.
Guys you are great!!!
!..! (]o.O[) !..!
oh and BurrMan: yes im into rammstein, ive seen them live and ive met Till the frontman on the streets in my hometown.
Pasolein
EDIT: please take a look at the attachment, thats the shape, but how do i get rid of those yellow lines?
EDITED: 28 Sep 2008 by PASOLEIN
Size: 55.8 KB, Downloaded: 97 times, Dimensions: 1042x702px
2021.7 In reply to 2021.6
This was just using network. I am surprised that the area marked on the MoI screen shot seems to render out without problems?
Brian
EDITED: 31 Dec 2008 by BWTR
2021.8 In reply to 2021.6
Those lines are from your construction method. Corner points tend to slice up the surface. So from your original curves, are there "seperation" points there? (Two curves joined perhaps)
If you look at the original curves and turn on show points, you can add a point on either side of those 2 points and then delete the two at each end of the line. Then when you create your surface it should be clear.
I think you may get a better/clearer answer here in a bit.
Burr
2021.9 In reply to 2021.6
Hi Paso,
Is there a reason why you want to get rid of the yellow lines?
Those are edges of surfaces that you have created - it is not an error to have edges, edges are always present on every surface that you create.
For closed surfaces it is normal for there to be a "seam" edge where the surface is closed.
NURBS surfaces are kind of like rectangular sheets of rubber. The sheet can be stretched and pulled in different ways, but to build a closed surface like a cylinder that is done as if you had taken a sheet of paper and rolled it up so that left and right edges were meeting each other. There will be an edge displayed in that area, it is a natural part of the surface and not an error or something that you need to get rid of...
For some kinds of construction methods you may get edges in areas where you use curves that are made up of multiple segments.
If you want to reduce the number of edges in cases like that, you can merge segments of your curves together by using Edit/Show pts to turn on control points and then select and delete the point where 2 segments are touching. That will fuse them together into a single segment.
A segment is one piece of a curve, like for example a rectangle is a curve made up of 4 line segments. You can use the Edit/Separate command to break a joined curve into individual curves for each segment, then they will select individually so you can see the segments that way.
But in general it looks like you have created your shape successfully and you should not really worry about those yellow lines unless there is some other problem with the shaping of the surfaces in that area.
2021.10
Hi all may be here is better way to do it !!!!!!
Seems there is a view missing on the Blue prints ;)
2021.12
Hi, There are several solutions to model this.
For a violin project, I lofted several cross-sections and then projected the top view.
Marc
Size: 198.7 KB, Downloaded: 103 times, Dimensions: 640x480px
2021.13 In reply to 2021.12
Its a boy!
2021.14 In reply to 2021.13
More than one way to skin a cat.
(Acknowledging that this may not be "sound" correct guitar making theory?)
Firstly, I created a slice off the top of Sphere. Actually a rotated arc.
Then extruded the Guitar profile and did a Boolean intersect.
I could cry with the simplicity!
Brian
2021.15 In reply to 2021.14
Just a little progress report.
Brian
2021.16 In reply to 2021.15
Grab a beer and your AIWL hat and rock!
2021.17 In reply to 2021.16
I did! I did!
Brian
2021.18 In reply to 2021.17
Just a quick render to celebrate my birthday--EVERYONE is expected to respond!
-----joke!
I have fun!
Brian
2021.19 In reply to 2021.18
veery nice brian happy birthday how young are ua 61
2021.20 In reply to 2021.19
Just a young 76 (Or is it 77----well something like that!!)
It's all in the mind you know!
Brian
2021.21 In reply to 2021.20
Please feel free to use the file anyway you want.
Be very happy if some learning/benefit to others was an outcome.
Brian
2021.22 In reply to 2021.18
On this guitar I would be strumming the sound of silence!
Happy Birthday! Mine is in 2 day's.
Burr
2021.23 In reply to 2021.22
Thanks, and to you for then.
Are you complaining about the lack of strings????
Do you need my hearing aids?
I can hear those 200 Chet Atkins songs I have on the computer without having turned the sound ON!
(I see the tune name and it plays in my mind!)
Memories were made of this (or is that I song title also?)
Brian
So in a years you will cant' read Tintin !
It's for 7 to 77 ;)
Happy BD!
2021.25 In reply to 2021.18
Happy Birthday Brian! Time for another beer! :)
Show messages:  1-5  6-25  26-27
