Modeling contest !!!!!
All  1-3  4-9
2003.4 In reply to 2003.3
OK, I did things a bit differently than that earlier tute, and my dimples layout is not ideal---
The problem that I would like help with is why I can not get a boolean diff with this?
Brian
EDITED: 31 Dec 2008 by BWTR
2003.5 In reply to 2003.4
It seemed to work fine for me over here, this is the result:
But I noticed that you have a couple of curve objects in there as well - make sure not to select those as part of the cutting objects because they will also try to drill holes as well which you don't want there.
I selected those curves and deleted them first to get them out of the way before I did the boolean.
2003.6 In reply to 2003.5
Thanks Michael
It helped and I needed a little patience to wait!
I LOVE MoI!
Brian
2003.7
If you have the patience, time and are crazy enough to model the ball accurately.
http://www.pat2pdf.org/patents/pat4560168.pdf
I suggest not to attempt FIG. 13A :)
2003.8 In reply to 2003.7
He,He,He----
NO< NO-- NO----you mean BE ACCurate!!!
Brian
2003.9 In reply to 2003.8
Hi, all
My result
Marcorhino
Size: 201.1 KB, Downloaded: 56 times, Dimensions: 800x524px
Show messages: All  1-3  4-9
