contours again
All  1-5  6-7
2002.6 In reply to 2002.5
MoI will do those curves minus the to loopback lakes in the middle.
I did this with sweep.
If it was important, I could paste back the two deleted lakes then turn on points of the surface and adjust it to match the lakes elevation.
But if you have rhino.....
Burr
2002.7
Well, yes, I have Easy Site for Rhino that is the best tool in my box for this and it's great that I can switch back and forth between MoI and Rhino.
Thanks, Burr, for pointing out that with some changes to the contour lines (without compromising the model) I can use other MoI tools like 'sweep' ...
Rhino is a great tool but I can certainly speed up some processes by using MoI as a sidekick ... and that will be more convenient when layers are implemented.
thanks all,
eric
Show messages: All  1-5  6-7
