Problem with export to modo (lwo)
All  1  2-4
2000.2
Because your mesh has n-gons. Since your object is a simple revolved surface, try exporting with the quad/tri option...
jonah
2000.3 In reply to 2000.1
Hi Tony - if you turn on vertices in Modo and examine the points in those areas you should see that a couple of the polygons in that area got created as 5 point n-gons instead of as 4 point simple quads.
It looks like you may have 2 5-point n-gons in there.
They will look something like this:
Notice the extra point along the side there with the red arrow pointing at it?
A few of these can be created sometimes right now in the seam area where a closed surface like a cylinder has its ends sealed together.
I will be looking at tuning this up in v2 pretty soon here to avoid making those.
But typically there should only be a small number of them.
2000.4
Thanks for the info guys. There weren't too many of these and didn't take too long to clean up but I would have preferred not to of course.
JB - Quads and tris had problems which were clear in the preview so I went with the ngons. I really wanted quads, and it looked like quads so I thought I'd done it :-)
Michael, I look forward to the tune up on this.
Tony
Show messages: All  1  2-4
