CNC contours parts from 3D models
All  1-16  17-19
1990.17 In reply to 1990.16
With only one selection 2 clicks, one rotation seems you obtain that you want ?
Seems a script can do that? (Rotate all selection, and the Scale 1D will be same result)
EDITED: 30 Sep 2008 by PILOU
1990.18 In reply to 1990.17
Thanks Frenchy Pilou for this illustration !.
Some détails concerning the script close to your proposition :
- In fact, i just need contours to be projected, not surfaces.
- Possibility to rotate a group of contours in the same time : interest of a script.
- Possibility to rotate on 0,X,Y plane(ground) contours which are not in the X,Z or Y,Z plan (your exemple show object in the Y,Z plan, axes behind object make me think about it).
Bye,
Pierre.
PS : I could pay for this script if someone is interested !(around 50 Euros ).
EDITED: 1 Oct 2008 by PIERREARCHI
1990.19 In reply to 1990.18
In fact when you have your contours any rotates axis toward any plan takes one second by hands ;
No need script for that ;)
I am not sure of the Scale 1D ! I suppose vertices are stacked on a same positions but always exist?
Maybe this can be produce problem?
Depending of what is the folowing next step?
Show messages: All  1-16  17-19
