move scale roate f BAckground images
All  1-10  11-15
1982.11 In reply to 1982.10
Hi okapi, I'm glad that will work for you - yes I should be able to add this in for the next beta which should be ready pretty soon. That was actually a screen capture of it working inside of MoI right there.
It will be a new button that will show up here:
When you have multiple images, the one that will be edited is the one that is highlighted in the list, so that part is a little different than dragging images.
1982.12
This is excellent.
Many times in blueprints you have exact dimensions for wheel base, total length, etc.
What a time saver!
This alignement will also valuable with the normal Edit frame box?
1982.14 In reply to 1982.13
Hi Pilou - no not currently, as you can see in this post here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1982.11
it is actually a special part of the Image command that you activate by pushing the new "Align" button in the Image options panel.
It isn't activated by doing anything on the edit frame, it is a totally separate thing from that.
I do want to add an additional kind of align/orient tool for objects as well though, but again it will likely be a new transform command and a separate thing from the edit frame.
1982.15 In reply to 1982.14
thx for the precisions :)
Show messages: All  1-10  11-15
