reset full view with object selected?
All  1-3  4-6
and you have not install
F9 Flip view under the mouse
script:if ( moi.ui.mainWindow.viewpanel.mode != 'split' ) { moi.ui.mainWindow.viewpanel.mode = 'split' } else { var viewport = moi.ui.getViewportUnderMouse(); if ( viewport ) { viewport.viewPanel.mode = viewport.name } }
F10 Right/ Left...etc under the mouse
script:moi.ui.mainWindow.viewpanel.reverseView( moi.ui.getActiveViewport().name );
F11 Full Screen :)
http://moi3d.com/forum/index.php?webtag=MOI&msg=207.55
EDITED: 18 Sep 2008 by PILOU
1981.5 In reply to 1981.4
Oh great, thank you. :-)
1981.6 In reply to 1981.3
Hi Nick - yeah it is the second click that will switch between just the selected objects or all objects.
Also one other note - if you right-click on the "Reset" button that is at the bottom of a viewport, it will apply the reset to all viewports same as the View / Reset All on the side pane.
Show messages: All  1-3  4-6
