Extrude Points
All  1-2  3-4
1973.3 In reply to 1973.1
Hi Burr, it would be possible but in most cases you can get the same result through other means.
Like Pilou mentions you can draw a line and use z-axis snap to build a point "extruded" in the up direction.
For extrude along a path - that would be the equivalent of making a copy of the curve starting at that point, so you can use the Transform/Copy command to get that same result now..
Sweep could be potentially different, but for planar curves using Offset would produce that same result as sweeping a point too.
1973.4 In reply to 1973.2
Actually I was meaning to use it with a set of points, that could be arranged in an odd pattern, draw only one curve to extrude. I could then use control points to manipulate the curves a bit, then use the csec tool to create my shape.
But since you mention the existing tool thing, I'm re-thinking if it can be done with the array tools new features.
Give me a bit to produce an example.
[EDIT]
No need for an example, It's the array with curve function! Duh. I just need to fool a bit to get it. I think to rotation none option does what I was asking.
Thanks Pilou for the nudge! Orivwah!
[EDIT]
Show messages: All  1-2  3-4
