Extrude Points
All  1  2-4
1973.2 In reply to 1973.1
Extrude a point along a line is the same than draw a line ;)
Extrude a point along a curve is the same than draw the curve ;)
Just extrude the curve
EDITED: 16 Sep 2008 by PILOU
1973.3 In reply to 1973.1
Hi Burr, it would be possible but in most cases you can get the same result through other means.
Like Pilou mentions you can draw a line and use z-axis snap to build a point "extruded" in the up direction.
For extrude along a path - that would be the equivalent of making a copy of the curve starting at that point, so you can use the Transform/Copy command to get that same result now..
Sweep could be potentially different, but for planar curves using Offset would produce that same result as sweeping a point too.
1973.4 In reply to 1973.2
Actually I was meaning to use it with a set of points, that could be arranged in an odd pattern, draw only one curve to extrude. I could then use control points to manipulate the curves a bit, then use the csec tool to create my shape.
But since you mention the existing tool thing, I'm re-thinking if it can be done with the array tools new features.
Give me a bit to produce an example.
[EDIT]
No need for an example, It's the array with curve function! Duh. I just need to fool a bit to get it. I think to rotation none option does what I was asking.
Thanks Pilou for the nudge! Orivwah!
[EDIT]
Show messages: All  1  2-4
