Making swept helixes
All  1  2-5
1960.2 In reply to 1960.1
Hi ghan, there is a plug-in available here:
http://moi3d.com/forum/messages.php?webtag=MOI&msg=1519.12
which allows for creation of a helix that is following a circular path, but there isn't currently any tool that will create a helix following a generic space curve.
Rhino does have a tool for doing that, so it is easier to create that particular helix curve in Rhino and then bring that curve into MoI.
If you would like to post your path curve that the helix should go around, I could create it for you in Rhino and send it back to you if that would help.
1960.3
Michael,
Thanks. I just made little sections of the spring and copy/rotated them around. It worked just fine and did not take that long.
Great software.
ghan
1960.4 In reply to 1960.2
But I guess it is possible with Solid++. I remember seeing something exciting on their old website - helix around curve even with scaling rail option! (it means the helix diameter, not diameter of "wire", altered smoothly). We want it :) -Petr
1960.5 In reply to 1960.4
Hi Petr, yup there are actually several things that are technically possible but that I have not had a chance yet to create UIs for...
Unfortunately the UI design can tend to be the most difficult part, just having the engine part work is not really the whole thing, although it certainly can help!
Show messages: All  1  2-5
