Can this be modelled in Moi?
 1-4  5-24  25-44  45-48
1952.25
Thanks Manz.
Anyone know how to snap the 2 shells exactly?? And then Join the two shells together to form one part which I can then perform a union Boolean with?
I want to go from this
to this
1952.26 In reply to 1952.23
Hi gizmo,
> How do I get these 2 componant to be snapped together exactly.
Pick all the original wireframe and drag it from the end of that highlighted curve indicated by the arrow and there should be a corresponding point on your model to snap to as shown.
1952.27 In reply to 1952.26
Hi danny thanks for the reply. Right that seems to work in a round about kind of way. But then when I join the 2 shells together there are faults with it?
I've included 2 files. One with the 2 shells which I'd be interested in knowing how you'd snap together as well because both are shells. Rather than the shell you aligned with the curve 'cage'.
The other is the shell created using the technic you say Danny but there are faults with it when I joined them. That means that when I come to choose say fillet it for instance it doesn't work?
EDITED: 11 Sep 2008 by GIZMO1990
1952.28 In reply to 1952.27
The union or join is probably being messed up with the fact that the 2 surfaces are "Barley touching" along the edges.
A solution would be to take say the bottom piece and make it "Bigger" so the edges stick through the top surfaces edges, then your Booleans should work.
[EDIT]Bad solution.[EDIT]
EDITED: 11 Sep 2008 by BURRMAN
1952.29 In reply to 1952.23
Hi gizmo,
> Can you only Boolean closed objects?
No, you can boolean open objects as well, however booleans are mostly oriented towards figuring out which pieces to keep and which to discard according to where they are located inside of a volume.
If the piece you want to cut is not a volume, it can be somewhat unpredictable which pieces will be kept and discarded.
In cases like that, switch to use the Edit/Trim command instead - it allows you to cut objects with one another similar to booleans, but you manually control which pieces you want to discard by clicking on them.
So in the case that you are describing use the Trim command instead.
> I've got the shell exactly how I want but how do I close it?
This would likely be easier with the method that I described earlier about building a larger surface first and them trimming it back.
When you build a surface like you have there with the corners of the 4-sided surface sheet totally smooth to one another, that will create a degenerate surface normal in that area and prevent some commands such as shelling or probably filleting from working in that spot.
That's another reason why it can be better to build a larger more simple structured surface first and then trim it, rather than trying to build a surface directly to your final outline which is more of what you would do if you were building with polygons - remember you are not building with polygons here, with NURBS it is generally better to use trimming and cutting type operations to make a final outline if that final outline is different than a 4-sided sheet.
> Here's an illustration of what I mean. How do I get these 2
The usual method is to find a key point like an endpoint and then grab the object close to that key point to snap on to it and drag it over to the matching point on the other object, Danny showed this above but also just to be clear here is a screencap:
1952.30 In reply to 1952.27
Hi gizmo,
re: shell with fault - if you zoom in you can see that the pieces did not get really aligned properly with each other:
The pieces could join because some parts of them were close enough, but other parts were not close enough so did not get joined into a single shared edge.
You'll need to get a better alignment than that to get a clean join.
But after that I still would not be surprised if you could not fillet it, because you've got those degenerate edges in the surface patch - that's where your 4-edged surface has a tangent edges on its surface corner instead of a distinct corner, that causes problems with offset operations and part of filleting involves an offset calculation.
Again if you would use the technique described earlier on building a larger surface then trimming it back you are more likely to avoid many of the issues you are running across, you are attempting to do things in a more difficult and low level way right off the bat and that is increasing the difficulty level for you by quite a bit.
1952.31
Hi gizmo,
Michael wrote: you are attempting to do things in a more difficult and low level way right off the bat and that is increasing the difficulty level for you by quite a bit.
This is so true, your head will explode ;) trying to do surfacing type stuff like that without exploring and seeing what MoI can and can't do or having a Cad/nurbs background.
But don't get too discouraged or frustrated, the more you find out about MoI and techniques shown on the forum the more easier it will become :)
I've attached your file, after having a play with it, and as Michael mentions there is a bit of low level work to be done before you can use the Boolean and filleting tools successfully so it is possible.
One hint is that if you look at the model you will notice it's in 4 pieces joined together, so I just worked on a 1/4 of it, got that right then mirrored and joined them together to make a solid then the holes and fillets were easy after that.
EDITED: 26 Jan 2010 by DANTAS
1952.32 In reply to 1952.20
Don't know if this is of interest/value.
My starting point was a sphere with thickness.
Does the pdf in the zip explain the MoI moves well enough?
I have enclosed the .car file for those who could use it.
I have fun!
Brian
EDITED: 30 Dec 2008 by BWTR
1952.33
Thanks again everyone for your input. The willingness of everyone here to help me out and explain things is greatly appreciated.
It is really frustrating getting my head around Nurbs concepts but I really want to crack it after several failed attempts over the years. Moi's user friendliness is proving to be my saviour in this aspect.
Anyway back to the case in point. I understand totally what people are saying but what I can't get my head around is how would I be able to create the shell (exactly how I want it) without doing it the way I have? Starting from a sphere I can't see how I would be able to precisely replicate the shell dimensions I want? Perhaps someone could try and do this and prove me wrong!? Use mine as a template but create it entirely differently?
As for how my model is currently. Danny, how did you achieve the result you had!? That's 'almost' exactly what I want! I'd just like the thickness of the shell to be less. As you said I've broken mine into a smaller part but how then am I to create the underside of it like you've done?
Thanks again in advance!
1952.34 In reply to 1952.33
Hi gizmo,
What version of MoI are you using, demo or V2 beta ?
1952.35 In reply to 1952.34
The demo. V2 is locked off to current owners isn't it?
1952.36 In reply to 1952.35
Hi gizmo,
Yeah it is , just wanted to know to see which version to use to try some things out , V2 has some new features which help reduce the steps.
1952.37 In reply to 1952.33
Hi gizmo,
Actually the key thing is not that you have to start from a sphere, but rather that you start from a piece that is extended larger than what the final result will be.
The sphere was just one example of such an extended shape - you can use other tools such as revolve or sweep to build a customized extended shape instead of a sphere.
Here are some steps for how to do this kind of an approach with your shape.
To start with I used these 3 curves. Especially note here that each of these 3 curves are simple planar curves, that is one of the biggest benefits of this approach, it is a lot easier to control and shape curves that are just 2D. The model file of the curves is attached here as pad_extended_trim.3dm
Select the top curve:
Run Construct/Sweep and select the central one as the sweep rail. This will create the extended shape:
One thing to watch out for there is you don't want to have a large profile shape that goes through a tight bend in the rail, which can force the swept surface to bunch up and kind of overlap through itself, you don't want that.
Now select the shape, run Edit/Trim, and select that 3rd profile curve as the cutting object:
That will cut that shape up and then the Trim command will allow you to pick which pieces you want to keep or discard, select this piece to remove:
Now with that trim complete, it will give you your basic form:
Note how that was constructed without having to build curves that swoop around in 3D?
Also another big benefit of this kind of construction is that shapes that are built to an extended simple form and then trimmed back will tend to have a very evenly curved shape throughout them. When you try to surface something to a fancier outline directly it will tend to cause different amounts of curvature in the surface as it approaches corners and pieces where your curve framework comes together.
Generally surfaces constructed in this extended manner will be higher quality in their curvature characteristics.
Now you can use Construct / Offset / Shell to turn this surface into a solid by giving it thickness:
This will cause a piece to kind of jut out past the original trim outline - you can select the shelled solid and use Construct / Boolean / Difference to slice it with that same trimming curve, which will cut the shell into 2 pieces and then you can delete this piece:
That leaves you with this shape:
Now run Construct/Fillet to round off the edges:
So to use this method, you have to construct your initial surface to be somewhat larger than your final shape will be, then you use trimming or boolean tools to cut it back to your final outline, rather than trying to construct your shape initially to the actual final outline like would tend to do with a poly modeler.
It's a much different approach and it may take a little while to get used to it.
Hope this helps show you how this approach can work though!
Once you get used to it, you can create shapes using just a very small number of 2D curves though, which tends to be really quick.
1952.38 In reply to 1952.37
And another slightly different approach.
Brian
1952.39 In reply to 1952.37
Michael, thank you so much for taking the time to explain that to me. I would not have thought to model like that had you not.
However, one step I do not understand though is where you Construct / Offset / Shell and then use Construct / Boolean / Difference to give the model volume. I don't get how you've done this? The offest seems brilliant but it doesn't 'close' the model or give you the option to? Also using Boolean Difference I don't see how you've managed to close the object?
I hope you can spare me some more time to fill in these last parts of the puzzle for me!
EDIT! Hold everything, just seen the 'Shell' submenu in Offset! What an idiot.
Anyway thats sorted now. I've got my shell looking great with thickness and a fillet. Now I've sweeped a circle along the shells outside curve and then attempted to Boolean/Union the 2 objects. Unfortunately it doesn't work? I've applied ajoin to both object but it hasn't made any difference. Furthermore I can't seem to 'jion' the sweeped circle? It only stays in 2 halves?ve attached the current file.
EDITED: 15 Sep 2008 by GIZMO1990
1952.40 In reply to 1952.39
Hi gizmo,
This is how I see it, the curve that is extracted from the model is quite complex as in, if you turn on the control points for this curve you will see there are a lot of points, so I think the auto solver for the sweep is having a hard time calculating a nice sweep, and if you zoom up into the joins, circled in red, you will see that the ends have gaps and are not square or plumb.
To get this sweeping more accurately, I again only worked on a quarter of the curve and placed the circle profile on each end of the curve 90 deg to each other, then swept it with no caps, then mirrored and joined.
I've attached your file with a completed sweep and one set up ready for sweeping on the model so you can see what I mean.
1952.41 In reply to 1952.40
Thanks DannyT. Right I see, I didn't realise that the rail I extracted would be so messy nor that its messyness would have an impact on my sweep operation.
Danny how did you break up the rail into 4? I don't know how to do this?
Is there anyway to cutdown on the messyness of extracted curves? I just took it for granted that the curve I extracted (via selecting the shells curve and copy and pasting) would be okay? I get the feeling that once an operation is performed on a surface it automatically creates masses of points? This is certainly something I wasn't expecting with Nurbs. For some reason I thought Nurbs would be immune from this type of thing...
1952.42 In reply to 1952.41
Hi gizmo,
Here's a quick video.
EDITED: 27 Mar 2009 by DANTAS
1952.43 In reply to 1952.42
Thanks for that Danny.
Right I'm still struggling with the peculiarities of this stuff. I've created a loop and I want to sweep a cirle around it and then union jointhe result from the shell.
Unfortunately when I try sweeping the circle it creates 2 half sections!? Why is this? I don't understand it? It creates a tiny gap between the 2 and it seems impossable to join them up again, using the join command doesn't work? Is there no manual weld or something like that?
Beause it making 2 sections when I come to union join the tube with the shell its going nuts and even more so when I try to fillet it after!
Could someone explain to me what's going wrong? I just don't understand why it seems so picky!?
1952.44 In reply to 1952.43
Hi gizmo,
To get a smooth sweep juncture, it is not enough to just have 2 points touching one another. To give you a bit of an exaggerated example, here are 2 curves that touch each other at a common point just like points you have labeled in red above:
Even though these curves touch at a common point, if you sweep them you will get this result:
You can see more easily in this case why the pieces do not mate up even though the 2 curves connect at a common point. It is because the curves are not totally smooth with one another.
You are running into this exact same issue with your curves - your pieces do not share a common tangent similar to the above, although your one happens to be much closer to being smooth so it is harder to see it initially.
A curve's tangent direction is defined by the end point and the next point to the inside.
If we look at these 2 points:
And then these 2 points:
Creating 2 extended lines that go through each of these points (here I used construction lines to do this):
Initially that looks pretty much like they are aligned, but if you zoom in:
You can see there is actually a deviation there - those curves do not have a common tangent so they are causing the same kind of effect as in the 2 sharp lines that I showed above.
I've attached a version of this curve pad_trued_tangents.3dm, where I lined up all the points to be exactly along a straight line (I drew in an extended line and snapped them all to it), with this version you should now be able to make a sweep where all the pieces join up exactly.
Show messages:  1-4  5-24  25-44  45-48
