Blender Importer
All  1-6  7-12
1943.7 In reply to 1943.5
> Is that Blender script option outdated by the current saving capability in MoI?
I don't think so - that script is to help Blender read the data in more easily, including the shading data.
MoI's OBJ exporter also writes that shading data as well, but I guess the OBJ importer on the Blender side was not very good about reading that shading data in, I think that's why Anthony wrote that importer to get a better import into Blender.
It is possible that Blender's OBJ importer has been updated since then to work better, I don't really know about that specifically though.
None of this part has much to do with MoI's saving capability - it is about Blender's importing capability. After all, it takes 2 pieces of code to make a successful data transfer, first the code for the export from MoI and then second the code for the import into the other application. It doesn't really matter if MoI's export is perfect if the second step (the importer in the other application) does not support certain things...
P.S. - when using this Blender import script, make sure to uncheck the "Weld vertices along edges" option in the Meshing options (click the little arrow in the lower-left corner to expand the dialog), the script needs unwelded points to be able to get the good shading data.
Message 1943.8 deleted 6 Sep 2008 by LEE
1943.9 In reply to 1943.7
Thanks Michael
This shows the difference in the basic import structure from MoI into--well ---Carrara!
For end shading results, in Carrara, I can not pick any difference.
As you say, various apps have varying import capabilities---It makes me so very, very cross!
(Is Lightwave,latest version, capable of doing just "normal" import of .obj files yet?)
Brian
EDITED: 30 Dec 2008 by BWTR
1943.10 In reply to 1943.9
You'd probably be more likely to see a difference on things that had some tightly curved areas next to larger flat areas - like filleted areas. Those are the kinds of places where the "just average neighboring faces" type smoothing calculation does not work so well compared to getting the accurate smoothing information.
Also you may not be able to see the shading problems until you use a reflective or highly specular type object material.
Yes, I've heard that there has been some progress on supporting reading in the "vertex normals" smoothing data in LightWave when doing OBJ imports now.
But I've also heard that there are still some bugs to work out, something about them coming in reversed or something like that, it didn't sound like it was quite all worked out yet but at least it has been going forward.
1943.11 In reply to 1943.1
Export your object/s from MOI as .lwo and then use the import script to bring the objects into Blender.
Load the script into Blenders text window an press Alt & P to open a file import window to navigate to your saved object on your hard drive.
If you have saved the import script into Blenders scripts folder then you can also load the file using a Python Script window from Blenders window buttons menu.
Finally. Don,t be tempted to "Remove Doubles" in "Edit Mode". It will mess up the normals with bad results for render.
Hope this helps......
Happy Blending!
1943.12 In reply to 1943.11
Thank you to everyone for these answers. I thought the script went into MOI somehow! lol... I will now be able to use it correctly! Appreciate the help.
Show messages: All  1-6  7-12
