Blender Importer
All  1  2-12
1943.2 In reply to 1943.1
Would not an Blender Importer script be to import from Blender into MoI?
Would not saving (exporting) from MoI as a .obj file be the way to take things into Blender?
Have you tried to export your MoI file as an .obj file?
Can show some screen shots to do this if you can not find it in the wikii.
Brian
PS--I just see that that script you mentioned is actually related to "exporting" to Blender and somehow involved with .lwo file type? (Seems complicated) I would forget the script and just export from MoI as .obj. (Lets know)
EDITED: 6 Sep 2008 by BWTR
1943.3 In reply to 1943.2
Yes, that would seem logical to call it an exporter and that's what I thought at first too. But if you look at the Resources page on the MOI site and go to section 2.5 you will see the Blender Import Script - it starts out like this:
Anthony D'Agostino wrote a custom blender .lwo import script to enable exporting data from MoI to Blender while preserving the accurate vertex normals to get high quality smooth shading
This script seems to be the best way of exporting to Blender...I just don't understand how to set it up and use it! LOL
1943.4 In reply to 1943.2
I beleive the script is more custom to what Blender wants.
"Anthony D'Agostino wrote a custom blender .lwo import script to enable exporting data from MoI to Blender while preserving the accurate vertex normals to get high quality smooth shading, Getting the accurate normals makes a significant difference in increasing render quality, it eliminates small shading glitches that happen when the shading normals are created just from averaging adjacent polygons."
You can read and see why here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=979.1
1943.5 In reply to 1943.4
Just curious.
Is not the current direct LWO export capability and settings in MoI much the same?
In fact much the same as the dropdown I use for saving as .obj ?(attached)
Is that Blender script option outdated by the current saving capability in MoI?
Brian
EDITED: 30 Dec 2008 by BWTR
1943.6 In reply to 1943.3
Hi mharr, it looks like there are some instructions for how to install a script in Blender on this page here: http://wiki.blender.org/index.php/Manual/Extending_Blender
quote:
If you find a script useful for you, download it to your Scripts directory and it will be there when you need it. In the default Windows installation, scripts are in the C:\Program Files\Blender Foundation\.blender\scripts folder
So I think that you are supposed to copy the import_moi.py file to that \scripts sub-folder, then it is supposed to show up as an option when you do a file import inside of Blender.
Does that seem to work?
1943.7 In reply to 1943.5
I don't think so - that script is to help Blender read the data in more easily, including the shading data.
MoI's OBJ exporter also writes that shading data as well, but I guess the OBJ importer on the Blender side was not very good about reading that shading data in, I think that's why Anthony wrote that importer to get a better import into Blender.
It is possible that Blender's OBJ importer has been updated since then to work better, I don't really know about that specifically though.
None of this part has much to do with MoI's saving capability - it is about Blender's importing capability. After all, it takes 2 pieces of code to make a successful data transfer, first the code for the export from MoI and then second the code for the import into the other application. It doesn't really matter if MoI's export is perfect if the second step (the importer in the other application) does not support certain things...
P.S. - when using this Blender import script, make sure to uncheck the "Weld vertices along edges" option in the Meshing options (click the little arrow in the lower-left corner to expand the dialog), the script needs unwelded points to be able to get the good shading data.
Message 1943.8 deleted 6 Sep 2008 by LEE
1943.9 In reply to 1943.7
Thanks Michael
This shows the difference in the basic import structure from MoI into--well ---Carrara!
For end shading results, in Carrara, I can not pick any difference.
As you say, various apps have varying import capabilities---It makes me so very, very cross!
(Is Lightwave,latest version, capable of doing just "normal" import of .obj files yet?)
Brian
1943.10 In reply to 1943.9
You'd probably be more likely to see a difference on things that had some tightly curved areas next to larger flat areas - like filleted areas. Those are the kinds of places where the "just average neighboring faces" type smoothing calculation does not work so well compared to getting the accurate smoothing information.
Also you may not be able to see the shading problems until you use a reflective or highly specular type object material.
Yes, I've heard that there has been some progress on supporting reading in the "vertex normals" smoothing data in LightWave when doing OBJ imports now.
But I've also heard that there are still some bugs to work out, something about them coming in reversed or something like that, it didn't sound like it was quite all worked out yet but at least it has been going forward.
1943.11 In reply to 1943.1
Export your object/s from MOI as .lwo and then use the import script to bring the objects into Blender.
Load the script into Blenders text window an press Alt & P to open a file import window to navigate to your saved object on your hard drive.
If you have saved the import script into Blenders scripts folder then you can also load the file using a Python Script window from Blenders window buttons menu.
Finally. Don,t be tempted to "Remove Doubles" in "Edit Mode". It will mess up the normals with bad results for render.
Hope this helps......
Happy Blending!
1943.12 In reply to 1943.11
Thank you to everyone for these answers. I thought the script went into MOI somehow! lol... I will now be able to use it correctly! Appreciate the help.
Show messages: All  1  2-12
