shelling problem
 1-13  14-33  34-35
1939.34 In reply to 1939.32
> Yes this one!
> I suppose we can't consider that like a perfect result ;)
Actually if you are looking for constant thickness, yes that is completely perfect as far as I can tell!
It all depends on what you are looking for - if you want equal number of vertices, then you will have to create a shape that does not have constant thickness. If you want constant thickness, that is what that shape I have there does.
I know it seems intuitive that an equal number of vertices will produce and equal thickness, but that is not the case - it is only case for completely symmetrical things like a sphere, you are just thinking of this object too much like a sphere or regular polygon when it has different angled pieces which produce non-sphere like results...
1939.35 In reply to 1939.34
Thx : it very difficult to fight the intuitivity!
Intuitivity want same numbers, your logic result seems more complex to make for a jeweler!
I am curious of the Marco's result wanted and realised
EDITED: 6 Sep 2008 by PILOU
Show messages:  1-13  14-33  34-35
