MoI Exercise #3 Consumer Product Design
 1-5  6-25  26
Raymond Loewy spirit design ;)
1919.7 In reply to 1919.5
Hey Grendel, no time wasted there, good job.
Now where's my Latte', 2 sugars thanks :)
Did you find any tricky bits ?
I'm still waiting for works from the others who voted for this product.
1919.8
Most of it was simple parts, I think the thing I would do over was the sweep to form the piece that joins the top and bottom. It turned out OK because I was really try to get my points correct on the line but I should not have created a line with a center line on a piece that straddles centerline of the model. Doing that can lead to a crowning surface right at the center. I should have used grid snapping and layed down and then adjusted points with symmetry. It still came out OK but it bothers me.
1919.9
Wonderful model, excellent render!
Thread respected!
-Will
1919.10 In reply to 1919.9
Here is my first WIP. (NOT as clever as some!!!!)
I guess "artistic licence" is allowed?
Brian
EDITED: 31 Dec 2008 by BWTR
1919.11 In reply to 1919.10
Looking good, Brian ! Keep it up.
1919.12 In reply to 1919.11
If of interest/value
1919.13
I think this will be my final for this, really happy the way it turned out and I had a lot of advice on adjusting my render setting for a better final image so big thanks to all who offered guidance.
EDITED: 31 Aug 2008 by GRENDEL
Size: 105 KB, Downloaded: 180 times, Dimensions: 1000x1200px
1919.14 In reply to 1919.13
Bravissimo! What else? ;)
http://www.youtube.com/watch?v=DfyeXrdZZ1o
PS a little video of the entiere process?
EDITED: 30 Aug 2008 by PILOU
1919.15 In reply to 1919.13
Hi Grendel....
Impressive result....
1. Could you share on how to create part in the image below ?
2. How long C4D render the final assembly ?
EDITED: 30 Aug 2008 by ANIS
1919.16 In reply to 1919.15
This is just a quick rough effort as a challenge on the idea.
Did you do in a similar way Grendell?
Brian
1919.17 In reply to 1919.16
I need your tips on how to construct the pipe sketch. Are you create the four arcs first ?
1919.18
I started with a circle, adjusted a few points and then trimmed it off in the top view to make the panel side flat. I then used a curve through point line to make the bent area, mirrored and joined all together. Then swept a circle along the curve. I've attached my top piece for you to look at.
1919.19 In reply to 1919.18
Hi Grendel....
Would you like to give us a gif fomat on how you can construct the sketch ?
Thanks !
1919.20 In reply to 1919.19
My effort was ALL made up of arcs. Doing mirrors as Grendel said.
I revolved the group to get the side angle slope, then, in the front view, did a trim of the downpointing lugs appropriate to the shape of the machine.
Ain't MoI great!
Brian
1919.21
Here is the gif
1919.22 In reply to 1919.21
Thanks Grendel...
Thats help me a lot...
Cheers !
1919.23 In reply to 1919.13
Very nice final render Grendel, even down to the barista foam pattern in the cup!
1919.24
No problem Anis, that is the purpose of the exercise. Forgot about the time, it is right at one hour for the render in C4D.
Thanks Michael, a small update with a little more tweeking of almost everything, now I am probably done.
1919.25 In reply to 1919.24
Grendel.......man, its not just your design, its the Look too. Incredible!
I would like to hear more on that side of your work too.
Show messages:  1-5  6-25  26
