MoI Exercise #3 Consumer Product Design
 1-13  14-26
1919.14 In reply to 1919.13
Bravissimo! What else? ;)
http://www.youtube.com/watch?v=DfyeXrdZZ1o
PS a little video of the entiere process?
EDITED: 30 Aug 2008 by PILOU
1919.15 In reply to 1919.13
Hi Grendel....
Impressive result....
1. Could you share on how to create part in the image below ?
2. How long C4D render the final assembly ?
EDITED: 30 Aug 2008 by ANIS
1919.16 In reply to 1919.15
This is just a quick rough effort as a challenge on the idea.
Did you do in a similar way Grendell?
Brian
EDITED: 30 Dec 2008 by BWTR
1919.17 In reply to 1919.16
I need your tips on how to construct the pipe sketch. Are you create the four arcs first ?
1919.18
I started with a circle, adjusted a few points and then trimmed it off in the top view to make the panel side flat. I then used a curve through point line to make the bent area, mirrored and joined all together. Then swept a circle along the curve. I've attached my top piece for you to look at.
1919.19 In reply to 1919.18
Hi Grendel....
Would you like to give us a gif fomat on how you can construct the sketch ?
Thanks !
1919.20 In reply to 1919.19
My effort was ALL made up of arcs. Doing mirrors as Grendel said.
I revolved the group to get the side angle slope, then, in the front view, did a trim of the downpointing lugs appropriate to the shape of the machine.
Ain't MoI great!
Brian
1919.21
Here is the gif
1919.22 In reply to 1919.21
Thanks Grendel...
Thats help me a lot...
Cheers !
1919.23 In reply to 1919.13
Very nice final render Grendel, even down to the barista foam pattern in the cup!
1919.24
No problem Anis, that is the purpose of the exercise. Forgot about the time, it is right at one hour for the render in C4D.
Thanks Michael, a small update with a little more tweeking of almost everything, now I am probably done.
EDITED: 30 Aug 2008 by GRENDEL
1919.25 In reply to 1919.24
Grendel.......man, its not just your design, its the Look too. Incredible!
I would like to hear more on that side of your work too.
1919.26 In reply to 1919.25
Thanks jiro, for the rendering I use two apps most of the time, either Carrara or Cinema4D. I am trying to switch to Cinema4D as my main one. I don't have a good feeling about the development of Carrara under DAZ.
I try to keep my scenes simple, in Carrara I would use a HDRI to drive the GI then one or two lights to fill in and pick up highlights. Maybe render out an AO pass to accentuate boundaries on components. I don't usually use a backdrop as this takes to long to render and then just drop a gradient in the background for visual interest
In C4D I use one or two area lights and an infinite light and an AO pass. I may or may not use lightcards if depending on reflection requirements.
Show messages:  1-13  14-26
