Another free renderer
 1-8  9-25
1910.9 In reply to 1910.8
Hi JTB....
Thanks for give me the information.
Would you like to give me some image produces from Kerkythea ?
1910.10
Here's one of my Galacteers Class 1 Model that I have posted that I rendered in Kerkythea. This was using an unbiased setting and I didn't bake it long enough to get rid of the noise.
Here is the same image after a noise removal filter. It cleans it up nice.
EDITED: 31 Aug 2008 by PHILBO
Message 1910.11 deleted 31 Aug 2008 by PHILBO
1910.12
http://moi3d.com/forum/index.php?webtag=MOI&msg=1788.1
This is the link to the turntable I made in Moi3d and rendered in Kerkythea !
Kerkythea rocks !
Peter
1910.13 In reply to 1910.12
Hi Rayman & All...
Where I can find kerkythea video tutorial ?
I have visited to the website, but the video tutorial is very limited.
Would you like to give me a kerkythea tutorial ?
Thanks !
1910.14 In reply to 1910.13
1910.15 In reply to 1910.14
Hi Pilou....
Ya, not enough for me. not clear. Are you use kerkythea at work ? its use different method & work flow compare to indigo in SK. I need more clear tutorial.
1910.16 In reply to 1910.15
it uses the 2 methods(unbiased (slow),and biased (speedy)) and seems one of the more advanced easy render to use (if possible) :)
But I have no time to learn all functionnalities and prefer simplicity of Podium or direct material render of Zbrush
Seems you must go to the Kerky forum for special question of use if tutorials shown are not sufficient
1910.17 In reply to 1910.16
I know it's not normally free but there are so many useful extras that it will combine with the MoI workings----Carrara 6 Std or Pro.
Carrara5 has been available with 3dWorld---FREE! Truly a $1000 app! (For those like me who have paid top dollars for Carrara over the years---WE CRY!)
Brian
1910.18 In reply to 1910.9
Well, I am an engineer so I think you wouldn't be interested for architectural renderings.... You will find many examples in KT gallery....Also take a look at the forum galleries....
OK, this is an example, just a wip....Btw, the design is not mine, it is an ugly building....
Size: 552.5 KB, Downloaded: 110 times, Dimensions: 1024x768px
1910.19 In reply to 1910.18
Woof! No arguments here...
1910.20 In reply to 1910.19
:)) I know, that's why I added this comment!
***Modeling Of Ideas***
1910.21 In reply to 1910.10
Hi Phil....
"Here is the same image after a noise removal filter. It cleans it up nice."
What is removal software that you have ?
Thanks !
1910.22 In reply to 1910.21
< What is removal software that you have ?
Any modern 2D prog can make that ;) (erase noise...clean...etc)
1910.23
Hi Pilou...
thanks, I use Paint.NET and found it.
1910.24 In reply to 1910.23
anther 2D free cool one is artweaver (a mix toshop + Painter classic)
http://www.artweaver.de/index.php?en_version
1910.25 In reply to 1910.24
I have found that the Noise reduction in Paint Shop Pro X works fantastic. I have also had great results with the GREYCStoration Plugin for the Gimp. http://cimg.sourceforge.net/greycstoration/
Show messages:  1-8  9-25
