StarWars Walker WIP
All  1-8  9-13
1907.9 In reply to 1907.8
Hi Michael.
Attached is the foot part model which shows rendering problems around the bevels on the foot.
Also see the attached jpg file with a rendering of the foot showing the black shading problems.
Mal
Size: 45.9 KB, Downloaded: 39 times, Dimensions: 1194x896px
1907.10 In reply to 1907.9
Hi Mal, thanks for posting the file.
Nothing seems to be wrong with the model - your image there looks like the kind of glitch that can happen if a program tries to create smoothing information by averaging polygon faces together instead of using the information directly from the original solid model. In areas around fillets where there are small polygons along side of larger flat ones that kind of averaging does not tend to work well.
If you export to OBJ format instead, then I think that Vue will likely be able to use the smoothing information that is stored in the file (which comes directly from the original model and so is much more exact) and that should eliminate these kinds of shading problems.
So could you please try an OBJ export and see if that gives you better results?
If it does not seem to be better, please try switching the "Weld vertices along edges" setting to the opposite (expand the Meshing options dialog by the arrow in the lower-left corner to see this welding option) - with welding off it makes a somewhat more simple structure to the OBJ file and a few programs will only import the smoothing information when this setting is off (I don't know if Vue is sensitive to that or not).
Also when you import OBJ into Vue, if there is any options that say something like "Enable vertex normals", then make sure that is enabled.
1907.11 In reply to 1907.10
Hi Michael
Tried exporting the foot as an object file with welded vertices and then non welded vertices.
See the results in the jpgs attached.
Artefacts are much less but still present in both models.
There are no options to consider normals when importing the models into Vue.
Mal
Size: 70.3 KB, Downloaded: 35 times, Dimensions: 1194x896px
Size: 71.2 KB, Downloaded: 36 times, Dimensions: 1194x896px
1907.12 In reply to 1907.11
Hi all.
Just an update on the AT-AT walker model.
The motor drive for the legs is included as a 3dm file(MOI) and shown in the jpg(rendered in Vue 6 Infinite).
Now to start on the body.
Any comments are welcome.
Mal
Size: 55.7 KB, Downloaded: 55 times, Dimensions: 1194x896px
1907.13 In reply to 1907.11
Hi Mal - were those exported using n-gons, or as "Quads & Triangles"?
If it was n-gons, one last thing to try is to use Quads & Triangles with welding off (again with OBJ format).
Show messages: All  1-8  9-13
