Tangent to Three Curves
All  1-10  11-13
1899.11 In reply to 1899.9
> No - an ellipse does not tend to work in calculations similar to these + automatic solution<
Don't you think someone,sooner or later will find a
mathematical solution
I would say 'Never say never'
1899.12 In reply to 1899.11
Hi Paolo,
Well, the problem is not that there is no solution, it is that there are a huge number of solutions of slightly varying ellipses.
There probably wouldn't be a good way for the algorithm to judge that one ellipse was better than any other, except for the case of having 2 equal radius values which is what the circle solution is...
To narrow down the huge number of solutions to a single one would probably require more steps like picking additional points or specifying a particular minor and major radius value. That is certainly possible to do, but it would make for a rather complex UI (kind of like a big "Ellipse control panel") for something that is just a rather obscure thing...
If building an ellipse in that specific manner is an important thing for you, you will probably need to get some specialized software that is focused a lot on ellipses and conic sections. Programs that are specialized in that will be able to devote a lot more detailed and complex UI to that problem.
1899.13 In reply to 1899.12
Ok Michael, i am satisfied with
your answer
Show messages: All  1-10  11-13
