Export .ai file - open in Inkscape
All  1-11  12-18
1889.12 In reply to 1889.11
Hi Michael T. - do you have CorelDraw or do you have the Corel "Photo" program?
If you have CorelDraw, try loading it into there instead of the Photo program - it should have better support for this format.
For now you'll probably need something like Corel Draw, Adobe Illustrator, or Xara to work with this 2D file currently - these programs are more focused on dealing with 2D vector graphics data so they should be able to open this file.
Many photo programs are only focused on bitmap handling and not so much on vector graphics data.
Inkscape is a vector graphics program but unfortunately they have not yet supported this older kind of AI file.
I guess the other approach you could do is to open it with Adobe Photo Deluxe and then save it out from there as a bitmap and then open that up in your Corel Photo program.
1889.13
Thanks Michael G.
I have the Corel photo program, not draw.
I will look ito those other applications as well.
Again, everyones help is appreciated.
Michael T.
Michael Tuttle a.k.a. mictu http://www.coroflot.com/fish317537
1889.14 In reply to 1889.13
I updated the ai file to version 9. Can go up to cs3 if you want. What format do you want it in? Did you want it converted to a bitmap (photo)? which program do you want to use your ai file in? I'll convert it for you.
Burr
1889.15 In reply to 1889.14
Thanks Burr.
I tried to read the updated.ai file into Inkscape and Corel Paint Shop Pro X. It did not give me any errors, but nothing appeared after opening it. I will continue to play around with the settings maybe.
Thanks again!
1889.16 In reply to 1889.15
That would be a version miss-match. For instance, if you try to read it into moi, it will be blank also, no error.
Trying to figure out version for version etc is your task. Your corel is an old package, probably not your best bet. Inkscape is a whole other animal.
Are you on Linux or just that it's free?
Inkscape strives for svg. Try to open this in inkscape.
If the svg file works for you, then you may want to go to the inkscape site and read up on there ai convertor. Since they want to do svg and adobe handles it differently (by keeping the ai and svg seperatly in binary) then there is a process to make your inkscape compatible with other packages.
Hope this helps!
1889.17 In reply to 1889.16
Here is a link from the inkscape wiki. The program you want is called "uniconvertor". It imports ai files up to version 9 and exports the ai as version 5, which inkscape can then deal with.
Again, scroll to the "existing conversion tools" and look for "Uniconvertor"
http://wiki.inkscape.org/wiki/index.php/FileTypes
Burr
[EDIT] But then again, Inkscape wants to be an svg program so use this tool to import your moi file then convert it to svg.
[EDIT]
EDITED: 19 Aug 2008 by BURRMAN
1889.18 In reply to 1889.17
Thanks Burr, I'll check that out later tonite.
Show messages: All  1-11  12-18
