network or other
All  1-14  15-19
1881.15 In reply to 1881.14
Hi Burr, it is a good idea to experiment with the different surfacing tools to see what you get - and it is certainly not a bad idea for when you want a rounded tip to think of revolve or rail revolve.
You just give up some of that "down the middle of the surface" control. So it is a little different, but still for many purposes that could be fine.
The nice thing is that revolve and rail revolve tend to make a nicely formed surface throughout, including right at the tip points. They don't tend to really have the same kind of problems near the tips as other commands do, for other commands the curves tend to go through a sort of rapid changing shape near the tip there which can make for some more difficult shapes in that area.
1881.16 In reply to 1881.2
Hi PaQ,
> The curves selection order is important in this case (I thought
> Moi is resolving it automatically, but some selection combo
> don't work I don't know why).
This bug is now fixed for the next beta - it was not properly testing every single combination to see if the 4 curves had a curve down the middle like that (and so was not good for Coons patch) but it would get it right in certain orderings.
In the next beta it will test all combinations properly so the ordering will not make any difference for this shape which is what was supposed to happen.
Thanks for reporting the problem!
1881.17 In reply to 1881.16
I think it was with a bit of luck, but this wing profile worked out well for me in MoI eventually.
Render is in Carrara.
Brian
EDITED: 30 Dec 2008 by BWTR
1881.18
Morning
So many answers with different possibility. I will try some of your suggestion.
Many Thanx
1881.19 In reply to 1881.18
Morning Apophis,
Mostly the first from PaQ was a legit answer. The rest was me trying things that didnt quite work for your exact curves. The only thing I found was if your curve shape is slightly flexable then the revolve would produce a nicer surface. Just revolve cant work on those exact curves.
Good luck,
Burr
Show messages: All  1-14  15-19
