Import Corel 2d file scale problems - New User!
All  1-3  4-12
1876.4 In reply to 1876.3
I have the latest version of Corel Draw. Just let me know and I'll send anything you need for testing.
Ed
Marysville Washington
1876.5 In reply to 1876.4
Hi Ed, I guess I'm just looking for any AI file that has an object of a certain expected size, like a rectangle of width and height 1 inch.
1876.6 In reply to 1876.3
Thanks Michael,
I figured out I needed to scale it, but did not have exact ratio, so I was using good old "trial and error".
Now I know how to! Thanks again for the quick reply!
1876.7 In reply to 1876.6
Hi Denny, I'm glad that you have a solution now!
But can you also please send me the file for me to test with? I would like to make some adjustments so that the scaling is no longer necessary in the next version.
1876.8 In reply to 1876.7
Here is an AI file from Corel Version 10. It uses an AI 7 export. If you need one from Corel X3 let me know, it may use an export of later value, just not sure if it makes a difference. Could also send an actual Adobe file (CS2 I beleive).
Burr
EDITED: 26 Aug 2011 by BURRMAN
1876.9 In reply to 1876.8
Heres a couple others. Zip from corel x3 with version 8 through cs2 ai export. One from adobe illustrator cs2.
Burr
1876.10 In reply to 1876.7
This is file from corel 12. This profile is 3.500 lng x 0.500 high.
Thanks again
Thanks Denny & Burr for the examples, I'll take a look here and see what I can do to preserve the scale better.
1876.12 In reply to 1876.1
Hi Denny, I have tuned up this AI file scale thing for the next v2 beta version.
The way it will work is that if you have your unit system set to either inches, centimeters, or millimeters before you import the AI file, it will scale from the "points" units into that unit system. Otherwise it will scale by 1/20 to get sort of more regular numbers.
So for the next beta you won't have to scale, just set your units to inches before you open the AI file and it will come in at the size you wanted.
Show messages: All  1-3  4-12
