Boolean Heaven
All  1  2-12
1874.2 In reply to 1874.1
MoI does not have any type of "twist" function. But you could rotate each row of cutting objects before you execute the boolean to punch out the holes. End result will retain the roundness of the holes, unlike the twisted version which will create a shearing effect on the holes...
jonah
1874.3 In reply to 1874.1
I've seen Michael post on this a few times Brian. Boolean is a way of life in NURBS but in Poly it's almost a No no. Seems it never follows down road well in a poly modeler!
I dont think theres a tool to twist that in MoI after it's created, but could you use a Helix as a path to array your original boolean objects to be twisted?
I'll poke around with you and see.
Burr
1874.4 In reply to 1874.3
Brian,
Here's a bit of poking I did. I created the tube, then a few objects to diff. I used the circle array, angle 30, vert 2 with the center of the tube as a start point. It creates a good rotation, though as Jonah said, It's not actually "Twisted" if thats what your looking for.
Anyway, Talk to you later,
Burr
1874.5 In reply to 1874.4
Hey!
That looks pretty good to me.
Thanks for the trouble. I will now try out.
Brian
1874.6 In reply to 1874.5
Whacco!
It Works!
Brian
EDITED: 30 Dec 2008 by BWTR
1874.7
I had a nice idea as I read the thread.
Hair was created with c4d and thel plugin Fast&Fur. Hope you like it. :-)
1874.8
That's really cool, Apophis!
-Will
1874.9 In reply to 1874.8
Good fun! (Could be done in Carrara for those who have it)
Brian
1874.10
For a moment there I though that was all geometry. Whew!
Ed
1874.11 In reply to 1874.4
Hey Burr, this was a really cool use of the "vertical step" option in Array Circular! Great idea to use that.
1874.12 In reply to 1874.11
Even Blind squirls eat!
Burr
Show messages: All  1  2-12
