SelVisible
1853.1
Could it be possible to improve SelVisible method to work also with control points / point objects? I wrote some kind of Lasso selection script myself, but after all I found out it won't work on points (actually, it would select all points in the scene due to using Invert command) what is what I thought it would... measure twice, cut once :)
Petr
1853.2 In reply to 1853.1
Hi Petr, please go ahead and add this to the wishlist.
It will unfortunately be somewhat difficult to add in though - I was able to add the SelVisible method in quickly because it used the same mechanism for targeting objects by clicking.
Points are always targeted by a click, they don't have a visibility determined for clicking, just for display only (where they get dimmed).
So they are not set up right now to use the same mechanism that the selvisible thing uses.
