kinky curve
All  1  2-8
1850.2 In reply to 1850.1
Hi Nick, currently there isn't any tool for that, but probably the "rebuild" tool that I would like to add in would be good for that.
It will basically reconstruct a curve by sampling some points along it and then building a new curve that goes through those points.
But it will maybe be a little while before I can get to that one, I don't think I will have a proper place to put it in the UI until after the object properties panel is done.
1850.3 In reply to 1850.1
Hi Nick,
In the beta2 version you can evenly space
point objects on a curve with Array on curve,
and use those points to reconstruct a single curve
EDITED: 24 Oct 2008 by PAOLOLOBBIA
1850.4 In reply to 1850.3
Thanks Paolo!
Very nice tips...
Hope you'll find some spare time for make a little tutorial about car modeling in moi....
Ciao
Luca
1850.5 In reply to 1850.4
Ok Luca,
I will try to make an image sequence
on my site www.zitfermo.eu
in september
1850.6 In reply to 1850.5
Thanks, really appreciate!
Very nice drawing in your site.
Luca
1850.7
@Michael: Ok, thanks.
@Paolo: Thanks. I have been doing the same process you described. I'm lazy and was hoping for a MoI 'magic wand' to clear up a choppy curve with 2 clicks. ;)
FYI: I come up with these kinky curves a lot when tracing an image.
-Nick
1850.8 In reply to 1850.7
That sounds like the "Reduce Nodes" feature in Corel Draw.
Very, very useful.
When I trace over an existing drawing, I just click along the curve at reasonable intervals to make a reproduction consisting of short, straight line segments.
Then I reduce nodes and it smooths out the curve and gives me fewer, manageable control points. I then make slight adjustments from there. It's a very fast way for me to build a complex curve that matches the original drawing.
Ed
Show messages: All  1  2-8
