Hi Paolo,
> "typing in numeric expressions"
> It works fine with the circles command.
> With lines i typed 2+2 space 5 space 0 enter,
> nothing happend.
Yes, like Petr mentioned the expressions were for single-value entries (like circle radius, offset distance, etc...) and not for x,y,z point coordinates.
But for the updated Aug-4 beta I have added some initial support for expressions for points as well.
The way it works is if your decimal point separator is not a , character then you can separate the coordinates by commas like: 2+2,5,0
Otherwise a second method is to put ( ) parenthesis around each coordinate, like: (2+2)(5)(0).
Currently the way you originally tried with pieces separated by spaces will not work. I also want to support spaces inside the expressions themselves so that is a more difficult one to support. But I'll try to take a look and see if I can add that in.
